Thread: Smartemp Heat Pump Pool Heatr
    May 2016
    Ottawa Ontario Canada
    2
    Does anyone have a service manual or links to this Smartemp heat pump? The format of the control panel display is amazingly similar to the Hayward Summit model. Purchased used in working order but no paperwork available to me.
    many thanks if you can help.
    18 ft above ground - 52" pool located in Ontario Canada
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Smartemp Heat Pump Pool Heatr
    looks like you're not the only one looking
    Pool Heater, SMARTEMP Heat Pump
    Here is the controller manual, i think.. http://www.viconics.com/DATA/TEXTEDOC/HP727-04.pdf
    I hope this helps
