Results 1 to 10 of 10
Thread: Water numbers
    Water numbers
    Hi, opened pool yesterday to light green waters. That was a first for us. Last 3 times to open with crystal cleat waters. Shocked the pool, and this morning was clear again. So out came my test kit. Here are my readings
    FC 14.5
    PH 7.8
    TA 100
    CH 140
    CYA 10
    So through pool math I need to raise CYA by adding Cyanuric Acid. For FC it said to add bleach
    Won't that raise the FC even more? My CC was 0.
    Thanks in advance for some help
    New Intex Ultra Frame AGP 18x52, 7200 gallons, sand filter, SWG
    pool school, TF100 test kit
    Donldson's Avatar
    NW Ohio
    2,896
    Re: Water numbers
    How did you get a CYA reading of 10?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Re: Water numbers
    Water to the top of cylinder. Maybe that would be a reading of zero?
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Re: Water numbers
    In the CYA test, you fill the tube until you cannot see the black dot at the bottom. Whatever measurement its closest to is your CYA level. Just to be safe, test again. Here are the steps just to be safe:
    -Fill the CYA testing bottle halfway.(bottom of label)
    -fill to the top of the label with your CYA mixing solution(the biggest chemical bottle)
    -replace red cap on the testing bottle and shake. Wait 30 seconds. Shake again.
    -squirt the mixed solution in the CYA long tube until you can't see the black dot. Take your time with this step don't immediately squirt it all inside
    If you keep getting consistent readings of 10, add more immediately. If you don't, most of your chlorine will evaporate, costing you more money in chlorine and not giving it enough time to sanitize your pool. If you get the granular CYA(it's marketed as conditioner and stabilizer), place it in a sock. Then place sock in your skimmer. Run pump 24/7 until it is all dissolved. Do not backwash for a week afterwards. The ideal CYA level is 30-40.
    Above Ground 30' by 54" 22,600
    Hayward S244T Sand Filter w/ 1.5HP Dual Speed Hayward Powerflo Matrix Pump
    TF100 Test Kit
    BBB ALL the way!
    Questions about pool care? Visit Pool School
    Donldson's Avatar
    NW Ohio
    2,896
    Re: Water numbers
    If it was cloudy then you can assume it was more than zero but less than 20 so I guess 10 is an ok estimate. I just get very concerned when someone posts a number for their CYA test that can't be measured with it
    Anyway, yes you want to add some CYA, you are low and with an SWG you are really low. PoolMath does not tell you what to do, you tell it what you want to do and it tells you how to do it. You enter your FC in the left column and then enter your target in the right column and it tells you what to do to get there. Same with all the parameters.
    Re: Water numbers
    This is my 4th year opening my pool and I have used the pool math and this site with the test kit all along. I got some CYA so will be adding that tonight. So I shouldn't be too worried about the FC being so high at 14.5, or will that change when I get my CYA level better? Thanks everyone
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Re: Water numbers
    As your CYA level rises, the ratio for FC changes. For instance, at 0 CYA, 15 FC would be a ton! But at 30-40 CYA, not so much!
    TF100 Test Kit
    BBB ALL the way!
    Re: Water numbers
    Thanks Blake. I think I understand it now!
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Re: Water numbers
    You're welcome! If you need anything else, just give us a holler!
    TF100 Test Kit
    BBB ALL the way!
    Casey's Avatar
    SW PA
    10,444
    Re: Water numbers
    How are you coming along Shari? Pool looking better?
