Results 1 to 7 of 7
Thread: Best Method for Testing CYA?
    FattyLumpkin's Avatar
    May 2016
    Massachusetts
    188
    Hi all - I don't have a T-100 (I had previously bought another and am not yet ready to replace it). Anyway, I need to test my CYA level -- any recommendations? Are strips reliable? Thanks!
    / 24k Gal, 18x36 Freeform IG Vinyl Saltwater / Sta-Rite MPRA6E-205L 1HP Pump / Sta-Rite System:3 Cartridge Filter / IC-40 SWCG / Dolphin Nautilus Cleaner / TF-100 Test Kit w/ SpeedStir / Taylor K-1766 Salt Test /
    Useful Links: Recommended Levels / SLAM / FC/CYA Chart / Test Kits Compared / Edit Your Signature
    Jun 2014
    15,253
    Re: Best Method for Testing CYA?
    Definitely no test strips or pool store testing. You can order just the CYA testing HERE for about $17 if that helps.
    May 2016
    Massachusetts
    188
    Thank you, I'll probably just get the full TF100.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Even better!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Quote Originally Posted by FattyLumpkin View Post
    Sent from my VS985 4G using Tapatalk
    You made the right choice by waiting. The TF100 has been upgraded to include a small bottle of the CYA standard solution. That way you can test it and see for yourself what you need to do so you see 50 ppm CYA using the 50 ppm standard. How far to hold it, how to hold it, even, how bright the light has to be. Everything. When you find just the right combination of factors so you get the right reading, you're golden. Then you just repeat that on your pool water and get an accurate CYA reading.
    Jun 2015
    Orange County, CA
    145
    Really? I would love to get the CYA standard solution, just to verify my own testing. The CYA test is so subjective and a known control would be helpful.
    17k IG plaster pool+ spa, Stonescape mini-pebble midnight blue, marble coping, Trex and porcelain tile decking, Pentair Intelliflo VSP x 3 (filter, laminars and spa jets), Pentair IC40, Pentair MasterTemp 400, Pentair Quad DE 100, Pentair CC 150 for laminars, Intellibrite 5G LEDs, MagicStream Laminars x 3, Intellitouch i9+3 automation with Screenlogic2, IntellipH, Dolphin s300i, TFTest kit, SpeedStir
    Richard320's Avatar
    Jan 2010
    19,067
    Quote Originally Posted by Ocgasman View Post
    Yes, really. It's R-7065. Two sizes available. TFTestkits.net
