Page 1 of 3 123 LastLast
Results 1 to 20 of 54
Thread: SWG the best answer?
    Jun 2013
    Freehold NJ
    133
    Hey guys,
    Wasnt sure exactly where to post this, but we have a beach house and leave our pool for several days at a time during the summer and at least 1 week a year. I hate to keep asking my neighbors to look in on the pool, so I was thinking a SWG would be the best solution. Everyone I know loves them bt Im just wondering is anyone here has used them and then switched back to chlorine....again, the only reason I am think ing about this is so we can leav the pool unattended often.
    Thanks
    38,000 gallon vinyl liner, True "L", Sand Filter, Hayward Heater, Diving Board
    Jun 2011
    Long Beach, CA
    2,790
    Re: SWG the best answer?
    One of the major benefits of having a SWG is being able to go away and have a less chances of the pool developing problems due to a lack of chlorine.
    Another option if you want to stay with liquid chlorine is adding a Stenner pump to dose the chlorine. This will have the same benefit as a SWG of being able to leave the pool alone.
    If you choose to go the SWG route, get one rated for 60k gallons.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    That is exactly the reason I installed a SWG before my pool was in, I needed a way to easily manage FC while I was away for 2 to 4 weeks.. My son and wife can both test the pool for levels if needed but it has been perfect the times I have been gone..
    I have my FC a little higher than recommended for SWG (about the same for non SWG) and my TA is lower and I keep my PH lower, this tends to run my water for a vinyl liner pool on the lower side of the CSI scale, I am adjusting my CH up to bring the CSI closer to -0.3..
    It can be done but testing while you are there is key to being able to leave.. yes I am using more of the SWG cell to keep the FC higher but that's what I bought it for, so if I only get 4 years out of a cell, I have accomplished what I wanted to be able to do..
    I hope this helps
    Jun 2013
    Freehold NJ
    133
    Thanks for the replies...I totally get the whole idea of taking care of all your chlorine needs with bleach, but I travel during the week as well and I as usual, I just cant rely on anyone to take care of things the way I want while I am away....Im a little anal...LOL
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    +1 another one to SWG making life easier with your pool. Not only will I never switch from salt back to bleach I will never have another pool that isn't saltwater. In case you aren't convinced yet.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    SWG user here. I was just gone for over a month without anyone to look after the chlorine needs of my pool.
    No problem whatsoever.
    The only people I know of who have reverted from SWG back to chlorine, were those who for some reason, did not like the feel of saltwater. (personally, I cant feel any difference).
    Divin Dave,
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    My auto injection of acid has given me similar piece of mind in longer than 10 day absences. No where near as critical as an out of wack FC level; but nice to know my ph levels are not redlining while I'm gone, particularly with more frequent auto fill of high ph water during the heat of summer adding to the usual upward creep of my ph levels.
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    Jun 2013
    Freehold NJ
    133
    Wow - very impressive, thanks guys...as I mentioned earlier, I am convinced that 99% of the people where I live have no idea about the importance of CYA levels and the relationship to the amount of chlorine needed in their pools. They all go to Leslies how tells everyon their CYA is "30", or dodnt even test for it. Mid way through the year their CYA goes up to 100 or so, but their still maintain FC at 2 - 3 ppm, if they even know. Algae comes, the added hundreds of "junk, blah, blah, blah." They get a SWG installed and Bam! This thing is automatically adjusting the chlorin amount but NOT adding CYA...its like magic...they have no idea why....but its the greatest thing in the world...
    I assume the Hayward AQR serious is the way to go? I have heard that one part of the board can get fried after a 4 years but its a cheap fix...correct?
    Thanks again guys and girls!
    One more question. the stenner pump doesnt monitor the amopunt of Chl....correct? just adds a measured amount...
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    ^that previously problematic part on the board has now been redesigned. I just switched this year to swg, aquarite with a t-15 cell and love it!
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    The Hayward AQR is a great product. The thing with the board going bad is true. But you dont have to replace the whole board. There is a component called a Current Limiter on the board that you can replace yourself if you can use a soldering iron. If you cant use a soldering iron, then Im sure you may know someone who can.
    The current limiter costs about 5$. Cheap fix vs replacing the whole board.
    Google 'replacing current limiter' or some such term and you can see how it's done. YouTube has videos about it.
    Divin Dave,
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    ^Dave, just so you know, Hayward confirmed the capacitor has been redesigned now on the board. I checked when I bought mine after another poster told me about the design change.
    Helpful Links:
    Jun 2013
    Freehold NJ
    133
    I know there are places that sell refurbed units...Im sure they just replace the capacitor...anyone have experience with that?
    Swampwomen...any idea when that capacitor redesign took place?
    Thanks again!
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,267
    I was just away for 3 weeks and the chlorine level held up fine with our SWG and did not get too high or anything. Up to a week between acid additions has been fine for our pool.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jun 2015
    Phoenix, AZ
    216
    SWG + Stenner for MA + Sense and Dispense FTW!
    Another SWG proponent here
    2015 build (link)| 16.5 K gal | Salt Water | IG rect | 35'x16' | 568 sf | 105 ft peri | depth 3'-5' | PV3 in-floor | 2 Venturi skimmers | MDX+SDX drains | T-CELL-15 SWG | Hayward Ecostar VS pump | Hayward 7220 DE Filter | Aqua Cal Icebreaker Heat / Cool pump SQ166 | Hayward Sense & Dispense PH Controller| Omnilogic | Pebble Sheen Blue Surf | Ultra UV | Stenner acid pump | Coverstar Automatic | TF-100
    Aug 2010
    Dallas, TX
    4,052
    You couldn't pry my SWG from my hands. In fact, recently my first one died and I ordered a new one right away. Especially with big pools like we have!
    You might want to look into the Circupool line. If you look at the output of the different brands, for a large pool you'll see where the Circupool 60 is probably what you want. I have the RJ-60+ mainly because Discount Salt Pool sold it to me for the price of the regular RJ-60.
    Full Market Comparison of Salt Water Chlorine Generators for Swimming Pools
    Jun 2013
    Freehold NJ
    133
    I never have an issue with my PH levels ramping up...is this an issue with SWG in general?
    Aug 2010
    Dallas, TX
    4,052
    Would you rather make weekly MA additions, or daily chlorine additions?
    Jun 2013
    Freehold NJ
    133
    Understood, I'm just saying I have never had to add acid to my pool becasue of high PH is that an issue with SWG? if soI'll look into the sense and dispense hayward system. There was aguys selling a brand new one on Craigslist but I didnt think I needed all that...
    Aug 2010
    Dallas, TX
    4,052
    It varies. Some people will float up to 7.8 and stabilize. I, on the other hand, have to make weekly additions. I'm working on lowering my TA more (I'm at 80 now to see if that works. If I get to 70 and still have swings, I'm going to go back to 50ppm borates.
  20. Back To Top    #20
    May 2016
    Troy IL
    476
    I guess I'm the only one that doesn't have a positive impression of saltwater pools. From my perspective, the salt eats things up, and you've still got chlorine in the pool, and you may well end up needing to maintain a stenner pump to auto feed acid. I'd rather cut out the middle man and just add chlorine directly, but I'm still somewhat new to this, and I don't travel a lot so I won't be away a lot.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
