Thread: Installed rigid piping this year, looking for feedback
    Jun 2013
    Green Bay, WI
    72
    So after spending my weekend up north building a deck on front of my camper i came home sunday night at 4pm to 80 degree weather (rare for may in WI) with some ambition left to start a rigid plumbing project on the pool with hopes of having it ready for memorial weekend (I can dream right!).
    After a trip to the hardware store i managed to get all my supplies in 1 shot and had the project done in just over an hour.
    After i stood back and looked at it completed, i have hesitation that it's not going to go well tonight when i fill the pool up, add the shock and fire up the pump.
    We just bought the house last June and i didn't bother plumbing in the heater and i used flex hoses. I also didn't have any valves in last year so i never cleaned the cartridge filter all season.
    But man, it just seems like i have a lot of pipes running around and i'm worried i'm gonna loose alot of suction and output pressure.
    Thoughts?
    FYI, behind that filter is my frog system which outputs directly to the pool.
    In case the pipe path isn't clear:
    Comes in from pool skimmer, through pump bucket, through pump, out to filter, in filter, out of filter to heater, optional valve to bypass heater, out of heater to frog, from frog to pool.
    Doughboy 24' x 48" (AG), AQUA Tools Cartridge Filter, Frog System
    2004 Sundance Cameo SPA
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Installed rigid piping this year, looking for feedback
    That is a nice system and I do not think you will have any issues, I bet your PSI is not over 13 with that setup Nice job!!!
    You know I have to ask, frog system, have you pulled the mineral (metal) part out, that is one of the worst things for your pool and we just do not want to see you have to start using metal out products if you don't have to..
    Jun 2013
    Green Bay, WI
    72
    Thanks for the vote of confidence on my new setup!
    As for the frog, i don't recall there being any issues with metals last season. Once i got the pool opened and the frog dialed in i never had to touch it aside from vacuuming it once a week.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    It is your pool and we will all respect that you can put whatever you want to in it. Just know that not one contributing TFP member would ever use a frog or any other mineral system in their pool. We have all helped far too many people spend a lot of time and a lot of money removing stains from their pool, green water, green hair and even at least one green dog. not kidding!
    Plumbing looks great!
    38,370
    Agree, the plumbing looks good, although I can not see how the heater bypass is plumbed.
    This concerns me:
    TFP does not just throw "shock" (whatever you mean my that) into the pool. If the pool is green or cloudy, you need to follow the ShockLevelAndMAINTAIN Process and to do so correctly requires one of the Recommended Test Kits.
    Have a good test kit allows you to only add what the pool needs.
    I also agree with the others to STOP with the pool frog before you have have nasty problems.
