Results 1 to 18 of 18
Thread: New AGP Install
    Apr 2016
    Laurel, Mississippi
    73
    New AGP Install
    I am currently installing my new AGP and had a couple of questions. The first question I have is about wall foam. When applying the wall foam to I go over the skimmer and return holes with the foam and just cut them out later when I do the Skimmer and return install? I am assuming I do but just want to clarify. My other question is once I install the liner, is there a time frame I have to fill the pool up? The reason I am asking is I plan to install the liner one day after work only want to fill it a little at a time so I can make sure I get the wrinkles out. Doing this after work each day I will only have a few hours of daylight. I am just making sure the sun won't hurt the exposed liner with no water. Thanks as always! I plan on posting some pictures of my install, I know how much every one loves to see them.
    24'x52" Quest Round AGP
    23" Hayward Sand Filter S230T, 1.5HP Matrix Pump
    Pool Rover Jr.
    TF-100 Test Kit
    30,429
    Re: New AGP Install
    I can't help much with your install but I would say you want to get your pool filled sooner rather than later. Others will be along with better answers so this bumps your question back to the top
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New AGP Install
    I would put the wall foam on then just cut out the ports and skimmer areas..
    The only issue with installing and waiting is weather, if there is not enough water to keep the pool down it can become a kite and fly away...
    Apr 2016
    Laurel, Mississippi
    73
    Re: New AGP Install
    My other question is this. If I install the liner and start filling how long do I have before the water may turn green? I still have to run electrical and plumbing for the pool.
    Pool Rover Jr.
    TF-100 Test Kit
    mbuice's Avatar
    Jul 2014
    Denton, TX
    95
    Re: New AGP Install
    You will not have long at all. I would get your electrical and plumbing done before installing and filling your pool. I see that you're in the south like me, and we're already at the point where any time that your water isn't treated and circulation it's going to be green in no time.
    As soon as your pool is filled you should immediately test the water and bring it up to the recommended levels for CYA and chlorine. If you absolutely must fill before you will be able to hook up your pump and filter, make sure you're at least adding chlorine as a sanitizer and stirring up your water.
    18 X 34 AGP 7ft deep end, 22,300 gallons. 250lb sand filter, 2 speed 1.5 hp pump. TF-100 Test Kit.
    Casey's Avatar
    SW PA
    10,453
    Re: New AGP Install
    You definitely need to get the pool filled enough to excerpt outward pressure on the walls because of wind. Wind alone can destroy a pool in no time.
    Apr 2016
    Laurel, Mississippi
    73
    Re: New AGP Install
    I have the pool filling now. I should have the electrical finished this weekend for sure.
    Pool Rover Jr.
    TF-100 Test Kit
    Apr 2016
    Laurel, Mississippi
    73
    Re: New AGP Install
    I will post some pictures of the progress so far.
    Pool Rover Jr.
    TF-100 Test Kit
    Apr 2016
    Laurel, Mississippi
    73
    Re: New AGP Install
    My pool came with a in line Chlorinator but I know this site recommends not using Chlorine tabs. My question is should I just not hook that up? I am planning on trying the BBB method on this site.
    Pool Rover Jr.
    TF-100 Test Kit
    Jul 2013
    Fletcher, OK
    3,353
    Re: New AGP Install
    you can hook it up, it will come in handy if you need to leave or go on vacation for a week pucks are great for that, we recommend knowing what you are adding..
    Apr 2016
    Laurel, Mississippi
    73
    Re: New AGP Install
    That makes sense. Thanks!
    Pool Rover Jr.
    TF-100 Test Kit
    Re: New AGP Install
    It looks great!
    Sharkline 24' round 54" aluminum AG pool. Waterway 2HP 125sq ft. cartridge filter. Using k-2006 test kit.
    Casey's Avatar
    SW PA
    10,453
    Re: New AGP Install
    Very nice!
    Apr 2016
    Laurel, Mississippi
    73
    Re: New AGP Install
    Thanks! It was a ton of dirt work. Had a 12" difference from low spot to high spot. Got it all dug out using a mattock and a square shovel. Took about 3 full days to get all of the dirt dug out and level.
    Pool Rover Jr.
    TF-100 Test Kit
    mbuice's Avatar
    Jul 2014
    Denton, TX
    95
    Re: New AGP Install
    Looking good!
    rickyislandgirl's Avatar
    Apr 2013
    Cedar Lake,IN
    58
    Re: New AGP Install
    looks great
    10,400k, AG 21 round, 1.0HP Waterway pump cartridge filter. TF-100
    johnnysnok's Avatar
    Feb 2011
    South Jersey
    192
    Re: New AGP Install
    My hands have blisters just from looking at your photos.............great job!
    Dough Boy 12' x 24' Oval
    Wedding Cake Steps
    1500 SF Timber Tech Composite Decking
    Video of my pool and retaining wall....Above Ground Pool Ideas - YouTube
    Stump's Avatar
    Jul 2013
    Oklahoma
    145
    Re: New AGP Install
    Excellent preparation and results.
    You will reap the benefits of your hard work with family enjoyment.
    Thanks for sharing.
    24' Reprieve RD/AG/13K gal Vinyl TFP method
    Waterway Clearwater 175 sqft Cartridge
    Hayward Power-Flo Matrix 1HP Pump 2-Speed
    TF-100 Test Kit SpeedStir Borate Insta Test
    Spreading TFP to All
