Thread: Need programming Generator
    Aug 2013
    Ottawa,Ontario
    35
    Good day everyone in pool land.
    This is our 4 season with our pool.We have had nothing but terrible service from our builder. Took us 3 seasons to get some stuff that they did wrong to make it right (nightmare). Anyways I'am trying to set up our SWG it is a hayward goldline automation. if anybody can help out that would be great.
    Thanks Luc
    22k,IG Vinyl,Hayward Dual Speed Pump,Hayward Cartridge filter C3030,SWG 9 Cell Pro-Logic, 4 Relay System,Dolphin Supreme M4
    Jun 2011
    Long Beach, CA
    2,790
    Re: Need programming Generator
    I'm not up much on automation, but give us a start on what you need. Is the unit hooked up and all that needs to be done is the programming?
    Aug 2013
    Ottawa,Ontario
    35
    Yes pretty much
    mas985's Avatar
    Pleasanton, CA
    11,743
    What kind of information were you after? The manual pretty much has all the programming how to's?
    Does your sig say you have a T-9 cell? That is pretty small for a 22k pool.
    Mark
    May 2016
    Albany
    12
    Quote Originally Posted by mas985 View Post
    Take this advice. Bought a house with a pool roughly that size and a T-9 cell. SWG wouldn't even work. I bought a T-15 and it worked immediately. Same system as you.
    Aug 2013
    Ottawa,Ontario
    35
    I agree on the cell be too small, but it is what it is, tried the manual can't seem to figure it out. Now it is saying a comm error. Guess I'll have to call in another so called professional.
