Results 1 to 18 of 18
Thread: liner feeling slimy or slick
    May 2016
    spring hill fl
    13
    First of all I am a total noob at this so please forgive me if I ask something stupid or ask for further clarification. My pool is starting to feel slimy. Here are my readings:
    FCC .5
    PH 6.8
    TA 80
    CH 25
    Just got a low salt light so I imagine that is one part of it. I am cleaning the cell in vinegar as we speak to make sure I'm not getting a false reading. I put the pool up about a month ago and added 135lbs of salt at start up. Filled with city water. My hardness has always been really low but I was told this is a non issue unless too high. I have not done any water drains but have had a lot of rain for a few days. I run my salt system for 7 hours and my filter pump for 8 hours.
    Total Noob!
    Spring Hill, FL.
    5455 gal AG Vinyl pool
    635t Intex filter (cartridge)
    Krystal Clear 7110 SWG
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: liner feeling slimy or slick
    You have algae because your FC is too low. Pool School - Chlorine / CYA Chart
    You need to SLAM your pool. Pool School - SLAM - Shock Level And Maintain
    Which test kit are you using?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Ya' need to get that PH up to 7.2 or better as well. You don't tell us what your CYA level is.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,506
    Yep, slimy is algae from low FC. Chlorine is set based on CYA level in the pool and the Chlorine CYA Chart. It is important to always keep FC at target level and NEVER let FC drop below minimum or the pool will be unsanitary and algae will grow. You can use bleach any time to bump up FC if it is getting low due to high swimmer load. PH needs to be between 7.2 and 7.8 at all times.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Slime is not good. Get a CYA reading, adjust pH, and SLAM before some slick walls degenerate into a green pond.
    May 2016
    spring hill fl
    13
    how do I get a CYA reading? just bought new strips. using Clorox pool and spa.
    Total Noob!
    Spring Hill, FL.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    With a proper test kit See signature.
    May 2016
    spring hill fl
    13
    Well shocked it, cleaned my plates with vinegar, and put stabilizer in the pool to keep from loosing chlorine. Bought a good test kit and all my numbers are good but on the high side except for chlorine which is 10+.
    Total Noob!
    Spring Hill, FL.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Quote Originally Posted by mdsmitty View Post
    Could you be more specific on the red parts?
    May 2016
    spring hill fl
    13
    I went to my local pool supplier and he suggested chlor brite which is a sanitizer, fresh n clear which is a oxidizing shock and Leslie's brand of conditioner. I also bought a test kit from them that even shows my stabilizer.
    oh and I did buy more salt to add but he said there is no way my pool should be low in salt with 135lb start up within less than a month of set up. but there was a lot of build up on my plates that I cleaned with vinegar.
    since I cleaned the plates I have not gotten a low salt light. I ran the system before I put the chemical in it.
    however he said that a new pool will always flux in readings and that I should go chlorine and keep my salt system off for a few months till the pool stabilizes and then switch back to salt. he said it was hard to start a new pool out with salt at first. sounded weird to me.
    Total Noob!
    Spring Hill, FL.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    You would do well to never take advice or products out of a pool store again.
    What test kit do you have that measures CYA? Is it Taylor-14--, something like that? If so what is your CYA?
    May 2016
    spring hill fl
    13
    ok now things are looking up hopefully
    th 250
    tc 5
    fc 3
    ph 7.8
    ta 120
    satbalizer 50
    I know the stabilizer is a little low but I want to wait for a few days for it to fully dissolve before I add more
    Total Noob!
    Spring Hill, FL.
    May 2016
    spring hill fl
    13
    Taylor Technologies K-2005 is what I got now
    Total Noob!
    Spring Hill, FL.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    The K-2005 doesn't come with a FAS-DPD test, so you need to add that.
    Also, 50 CYA is plenty, I would remove any socks or other undissolved CYA immediately.
    The target for 50 CYA is 6 and the minimum is 4. Do you have a good understanding of the SLAM process? Pool School - SLAM - Shock Level And Maintain
    May 2016
    spring hill fl
    13
    I guess not because I thought cya for a swg pool was 70-80.
    Total Noob!
    Spring Hill, FL.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    You are right, sorry I missed that in your signature, my apologies.
    e: However, your SWG should be off until you have completed your SLAM anyway. And a SLAM is easier with a CYA of 30ish.
    May 2016
    spring hill fl
    13
    right now I am wondering if my swg is working properly to let my chlorine levels to drop so low. cleaning the plates took care of the low salt light. I also did not have any cya in the pool but that was due to me listening to my father who has the same set up in Indiana and doesn't believe in putting chemicals in his pool
    Total Noob!
    Spring Hill, FL.
    Jun 2014
    15,217
    mdsmitty, Mr Bruce is giving you some good advice, so stick with it. You may be a "Noob", but in some ways that's good - no bad (old) pool habits. Starting with TFP is a good thing. Some key reminders:
    - SLAM now while your CYA is still low to save on bleach. Regular bleach is what you need to use right now. Nothing else. Give the SWG a break until after the SLAM.
    - You need the "FAS-DPD" (powder & drops) test portion to test higher FC levels. You can order it HERE.
    - Stick with the basics and principles you read in the TFP Pool School (link below) and you will do fine.
    - Definitely stay away from the pool store and their free testing. You will spend way too much on products that will not clear-up your water.
    Good luck!
