Thread: Need a new flow meter dirt Liquidator. Any ideas? ?
    Hi All,
    Well it seems my flow meter finally cracked and is not functional any more. Trying to find a replacement and dealing with Hasa is like pulling teeth so I'm looking for an alternative. I currently have the 3/8" set up. I think I find several options but not sure on the ideal flow range. The Hasa is just marked to 5 but 5 what?
    Thanks!
    Joe
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Ellington, CT
    262
    Re: Need a new flow meter dirt Liquidator. Any ideas? ?
    Mine cracked a couple years back and I never replaced it. I use a pinch valve to control flow and use the stock valve as a shutoff valve.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
