Thread: Draining my pool to clean before opening
    May 2015
    Vermont
    1
    Hello everyone, I have a 27 x 52in above ground pool and was thinking about draining it to get a really good clean to the liner, last year we had some trouble with LG and had a hard time keeping stuff clean for some reason... I was wondering if it was a good idea to drain it to clean the liner first off and how low we can drain it safely without compromising the walls of the pool. Also is there any suggestion on what would be a good cleaning agent for the liner?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Draining my pool to clean before opening
    Welcome to TFP!
    The best way to clean your liner is to vacuum, run the filter 24/7 and SLAM the pool. Draining is not necessary and really doesn't help as much as you'd think.
    Donldson's Avatar
    NW Ohio
    2,895
    Cleaning the liner in the Spring isn't going to do anything to prevent algae (I assume that is what LG means) during the season. You have to maintain a proper chlorine level to keep algae from growing.
    I see you joined a year ago, but have you discovered the Pool School yet? It is full of tons of good information that can help you keep your pool clear and algae-free.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
