Thread: Anyone have this filter on an intex
    Jun 2012
    Central Alabama
    55
    Wondering if this filter will work with a 16x48 intex? Would I only need the hose adapters that can be found on amazon?
    http://www.walmart.com/ip/Pro-Above-...1.5HP/35093944
    Intex Ultra 16x48
    Intex 2650 Sand Filter
    Installed June 2, 2012
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,526
    Re: Anyone have this filter on an intex
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jun 2012
    Central Alabama
    55
    Jeff, what parts did you use to make the extra port for the robot and footwash setup? I know about using the conduit parts to make a pvc connection but it appears you have just screwed the intex hose onto pvc threads without any modifications.
    Intex Ultra 16x48
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,526
    The Intex hoses will screw directly onto a 2" male PVC fitting. But the threads are slightly different so the collar gets tight before you can screw it down enough to prevent leakage. But if you insert two 2.25 x 1/8" rubber washers, it will work without leaking.
    It was only able to find 2 3/8" diameter washers at my hardware store. They work, but you have to jam them into the Intex collars and they don't lay flat. I think 2.25" would be a perfect fit.
    Pentair IC40 SWG
