Thread: How much bleach to start
    May 2015
    Brooklyn NY
    46
    Hello. My pool is an above ground 12x18 oval pool and have a swg. I know that the first thing my pool needs is chlorine. Can anyone tell me how many jugs of bleach I should put in to start? The pool is about 6000 gallons. Thank you.
    Salt Water 8000 AGP 12' X 18' X 54" - Hayward S166T 16" Sand Filter w/ 1.5HP Power-Flo Pump - Hayward Aqua Trol RJ Salt Generator System
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: How much bleach to start
    Use Pool Math (link above) to calculate based on gallons and CYA.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,500
    Chlorine level is set based on your CYA level and the Chlorine CYA Chart. Always keep it at target and never let it drop below minimum.
    This page is also handy, Pool School - Water Balance for SWGs
    30,426
    Gotta test first. You can't tell how much to add until you find out how much you have to start with. Probably zero but I want to emphasize you must test all parameters first.
