Thread: Question about opening pool
    May 2015
    Brooklyn NY
    46
    Hi all. I am about to open my pool tomorrow and forgot what could be a very important step. When I closed the pool after the summer I drained all the water out of the sand filter. I hooked everything back up and would like to know if I have to add water into the filter or can I just attach all my hoses and allow the pump to do its job to get the water in the filter? Also, what setting should I set the multipurpose valve when I first start? Should I backwash or is it OK to just put it to normal operation and hope for the best? Thank you
    Salt Water 8000 AGP 12' X 18' X 54" - Hayward S166T 16" Sand Filter w/ 1.5HP Power-Flo Pump - Hayward Aqua Trol RJ Salt Generator System
    22,543
    Re: Question about opening pool
    If the water level is high enough, you can just let the pump fill up the filter.
    If you backwashed the filter at the end of last year, then you can just set the multiport valve to 'filter' to start with.
    By the same token, if you backwashed it at the end of last year, I wouldn't worry about backwashing it to begin with.
    May 2015
    Brooklyn NY
    46
    OK cool. Thank you . Going to start it up right now and hope all goes well.
