Results 1 to 8 of 8
Thread: Cloudy water with perfect numbers
    I opened my pool, cleaned out the junk, slammed and balanced using BBB, and my numbers seem to be right, but the water is still cloudy after a few days. I passed the overnight test and I am wondering if I need to slam again, give it time, or is there something else not showing in the tests that I should be looking for?
    FC: 5
    CC: 0
    PH: 7.7
    TA: 100
    CH: 230
    CYA: 35
    Thanks!
    30K Gallon Vinyl Inground
    Jandy DEL 48 DE Filter
    BBB Method
    Taylor FAS-DPD Test Kit K-2006
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,176
    Re: Cloudy water with perfect numbers
    A SLAM is not a one time event, it is continuous until all three criteria are passed.
    Re-read the directions on SLAMing your pool in the How To section of Pool School and follow that procedure completely to the end.
    • CC is 0.5 or lower;
    • You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    • The water is clear.
    When all three are true, you are done SLAMing and can allow the FC to drift down to normal levels.
    Support the site
    Thanks! I guess I am rusty after a long winter
    BBB Method
    BattleOfYakima's Avatar
    Apr 2016
    Central Florida
    1,505
    Hehe back to shock FC for you and maintain until you can read the year off a quarter at the bottom of the pool! Just kidding. Mine clears faster with at least one brush a day and a vacuum every few days. You can do a test pass with the vacuum and, at least for me, the bottom (through the cloudy water) looks stronger blue. That's how I know I need to vac the whole pool when I'm clearing up cloudy. Don't forget to watch that psi gauge and do appropriate filter care as needed.
    If I was effective, and your pool makes you smile, please make me smile and CLICK HERE to Become a TFP Supporter!
    Also, please make AmazonSmile donate to TFP by CLICKING HERE, at no cost to you!
    My Florida Pool: 20k IG plaster cart K-2006 | Washington State Pool I help with: 17k AG vinyl sand TF-100
    May 2016
    Clermont, Florida
    27
    Assuming that your filter is working correctly. Its worth a look.
    Quote Originally Posted by BattleOfYakima View Post
    I shocked last night as suggested and came home from work today to a crystal clear pool. I can literally read the date off a quarter on the bottom of the pool
    I am pretty sure if I went to my local pool store, they would have sold me clarifiers and other junk. This forum is so helpful and saves me so much $$, I just became a Gold supporter!
    Long live TFP and BBB!
    Thank you all!
    BBB Method
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by poolnj View Post
    Thank you all!
    Best to do the OCLT to make sure it's safe to let the FC drop!
    May 2014
    Franklin, NC
    9,176
    Quote Originally Posted by PAGirl View Post
    I agree. Many folks stop he SLAM just a little too soon before all the bad stuff is eradicated and regret it later.
    Support the site
