Thread: Help removing sheared drain plug from pump housing
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    I started my pool opening today and everything went well up to the point of installing all the drain plugs at the pad. I managed to shear the head of a nylon drain plug at the front of my hayward unit and need to figure out a way to back out the screw body at this point. The plug head had a rubber washer that compresses against the ABS housing to make the seal, so I doubt it is water tights at this point.
    I have given consideration to cutting a slot in the screw body with a hot screw driver or running a screw extractor in it, which will require more clearance than afforded by the suction side lines (nearest I can tell at this point).
    As you can see from the picture there is not a lot of room here.
    I hope this isnt the first time this has happened and some of you may have an easy solution. Any suggestions are welcome
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    Re: Help removing sheared drain plug from pump housing
    Heat up the tip of a flat head screwdriver and push it into the plastic. Allow it to cool and unscrew. Donít get near the threads.
    Support the site
    May 2012
    Cincinnati, OH
    189
    Thanks for the confirmation JamesW. I went out at lunch and bought a replacement plug. This evening I used the hot screw driver and had it out in less than 5 minutes and was able to get the filter charged and finish opening.
    I was not overly aggressive with the plug, it spun out so easily I suspect the female threads had some grit even after hitting them with a tooth brush or the old plug was just brittle.
    All is good in my corner of the world.
    Good job. Thanks for the update.
    Support the site
