Thread: Intermittent Autopilot error
    May 2016
    Miami, FL
    14
    I'm trying to figure out what's wrong with my Autopilot. It will be working fine for a few hours at a time but then it gives either the "low amps" or "check cell" warning.
    I don't think its the cell because I have 2 of them and have changed them and cleaned them and it still gives the same error. The salt level is about 3500 ppm. I thought it could be the power cord, so I cleaned it out and made sure the connections were dry, but still after a few hours I get the flashing warning light.
    One thing I noticed is that I get fluctuating readings on the control panel when I run the test program. For example, sometimes it will read 29 volts and sometimes 18 volts, sometimes 6.0 amps and sometimes 2.9 amps.
    My questions are: is it actually running normally when the light is not flashing, or is it just that the warning light will only flash for a certain time period and then turn off?, could a bad fuse be causing this?, is a bad power cord the most likely cause?
    The Autopilot control panel itself is 12 years old and the power cord is about 3 years old. My first power cord lasted about 9 years.
    Jun 2011
    Long Beach, CA
    2,781
    Re: Intermittent Autopilot error
    Welcome to TFP!
    That might be a symptom of a bad cell. The cell changes polarity and it could be that when it switches the polarity it will either be the good side or the bad side of the cell. Are both cells old?
    May 2016
    Miami, FL
    14
    Quote Originally Posted by ping View Post
    Welcome to TFP!
    they each have about 2-3 years of use so far
    the reason I have 2 is because I replaced the last one prematurely a couple years ago - I thought the cell was bad but it turned out to be a corroded banana plug on the power cord.
    Jun 2011
    Long Beach, CA
    2,781
    Put it in boost mode and wait 30 seconds and report back the voltage and amps.
    This thread might be of help also, Autopilot Systems - Warnings Low Amp - Cell?.
    May 2016
    Miami, FL
    14
    I checked it first before boost mode and it was 17.0 volts/5.0 amps, then put it in boost mode and checked a minute later and it was the same 17.0 volts/5.0 amps
