Thread: losing 4 ppm FC daily
    Kathe's Avatar
    Jun 2015
    Saline, MI
    47
    My CYA is 32. If I add chlorine in the evening, it is the same ppm in the morning. But....in the sun, and 70 degrees, I am losing 4 ppm FC per day. I'm worried about what it will be when it gets REALLY hot out! Water temp is only 71. Should I add more CYA?
    Above ground 27' round, 17,000 gal., 52" high; vinyl liner; TropiCal 96,000BTU Heat pump; Integrity A Frame Ladder; Solar Blanket, Aqua Cover by PolyAir Corp, thermotex clear, 5 yr. warranty, cartridge filter., Clear Bay Cartridge CBA2-10043 (two to switch out when cleaning); New pool as of 6/1/15.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: losing 4 ppm FC daily
    Go to 40 cya and see if it gets an "attitude" adjustment. Adjust your minimums and targets appropriately. I keep mine at 60 in Texas.
    Kathe's Avatar
    Jun 2015
    Saline, MI
    47
    Quote Originally Posted by woodyp View Post
    OK. Thanks!
