Thread: New Pool, New to TFP - current levels
    Oct 2015
    Windsor, ON
    12
    Hello all,
    New pool owner (complete newbie), also new to TFP. Happy I found this site, I've spent a lot of time browsing around!
    New pool opened a few weeks ago, filled with the hose. So far here are my levels. I added a few gallons of chlorine yesterday.
    PH: 8
    TA: 120
    CYA: 0
    FC: 2
    CC: 0.5
    I don't have a salt tester yet, but easytouch says its at 3350ppm.
    PB set my SWG to 50%.
    From what I am reading I need to lower PH, and add stabilizer, and chlorine?
    I am testing with a Taylor K-2006.
    Thanks!
    Mike
    16' x 34' Freeform Vinyl IG Pool, ~ 15,000 Gallons, Pentair Intelliflo VF 3HP, Pentair System:3 Cartrige Filter, Pentair Max E Therm 333 Gas Heater, Pentair IC40 SWG, Easytouch 8, Deck Jets, Intelibrite 5G Pool & Landscape, Built April 2016
    Jan 2012
    'burbs of Augusta, Georgia
    7,257
    Re: New Pool, New to TFP - current levels
    Yup- you need to do all three items you list. Do the pH first, then the CYA can be added to a sock and floating in front of a return. Then it can dissolve at its own pace (helped by an occasional squoosh by hand) and as soon as you stand up from hanging that CYA sock, go ahead and add the necessary liquid chlorine to get your level up.
    Have you started reading Pool School yet?
    Welcome!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    That is a good start!
    Start here in Pool School, Pool School - Getting Started
    Oct 2015
    Windsor, ON
    12
    Thanks!
    Read it last night, and re-reading today!!
    DFW, TX
    24,450
    Yeah, I had to read it 30 or 4 times for it to start sinking in!
