Thread: Pool Light Question
    Apr 2016
    San Diego, CA
    115
    Pool Light Question
    What we thought was a burned out light bulb turned out to be a tripped breaker after a storm. While troubleshooting we removed the lens to look at the bulb. At this point the light works again but I have a question before putting it back in the water. I've read that some people replace the rubber seal when they change the lightbulb. Is the purpose of that to keep the rubber seal from getting to old? Do I need to replace it every time I take the lens off? Basically I'm trying to figure out if I need to replace mine right now since I removed the lens or if it's ok to reassemble the light and reinstall it as is.
    11,500 Gal Fiberglass IG Pool. Hayward cartridge filter with Pentair 3/4 HP pump
    500 Gal Fiberglass AG Spa with cartridge filter
    Taylor K-2006 test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Pool Light Question
    Generally you replace the gasket because in a perfect world you would only open that every few years. If the gasket appears in good shape and is flexible to make a good seal you should be able to re-use it.
    If there is any question as to weather it will make a good seal, replace it.
    Support the site
    Apr 2016
    San Diego, CA
    115
    Sounds good, thank you!
