Thread: "Acid Magic" buffered Hydrochloric Acid - any opinions?
    I saw this product advertised. Has anyone used this or has an opinion?
    http://www.horizonpoolsupply.com/websit ... ItemID=883
    Thanks
    Amir
    7500 Gallon Kayak, 1HP Sta-Rite Pump, Pool Pilot DIG-36 SWG, AquaCal H100 Heatpump
    Guest
    Re: "Acid Magic" buffered Hydrochloric Acid - any opinions?
    It's been around for a while but I have never used it. It is a buffered muriatic acid according to the company website andis not approved for pool use in California. (then again, neither are borates!) It is more expensive than regular muriatic acid and it's interesteng that while they claim fume free and non burning they still recommend gloves, goggles and proper ventilation because it is still basically muriatic acid.
    Mar 2007
    San Rafael, CA USA
    12,082
    According to this fact sheet they have buffered the acid in such a way that it can increase inorganic phosphates (aka orthophosphates). So be careful when using this acid in the pool. Though phosphates should not matter, the amount could accumulate enough to cause calcium phosphate scaling especially in high CH environments. Also, if your pool was low in phosphates before, then the increased phosphates will make the pool grow algae faster if you let the FC/CYA ratio get too low.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Not sure I want anything to do with something that says magic on it.
    sounds like something that would be sold at night - off the back end of a horse drawn wagon!
    Divin Dave,
    So they attempted to junk up the acid with extra stuff just to make it more user friendly? Honestly I can't see a reason to pay more for it if it's just gonna achieve the exact same thing. It's really not that hard to deal with unless you have never seen it react, and don't have a good respect for what it does.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by BluenShiny View Post
    I agree. plain acid is all you need. I just use common sense and caution as with any chemical handling.
    Essential Links:
