Results 1 to 16 of 16
Thread: Backup problem
    Apr 2014
    Kansas
    9
    Backup problem
    I had a new problem when opening the pool this year. I can't find anything even similar in the forum. Everything seems to be working OK, water is clear, pump is working fine, filter pressure is the same as usual. But when I shut off the pump, all the water from the filter, pump, and hoses shoots up out of the skimmer. About 6 feet in the air plus back into the pool. Very suddenly and every time. You have enough warning from the gurgling to get out of the way. Barely.
    I don't even know if the problem is with the filter, the pump, or something else. It's like there's a valve that should be preventing that, isn't working. Is there such a thing? I really need some ideas.
    13K above ground Matrix,
    Pentair sand filter 21"?,
    1.5 HP Pentair Dynamo pump,
    everything new in 2013
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: Backup problem
    Easy. Your filter is full of air.
    The bubble compresses under pressure when the pump is on. As soon as the pressure is off, it expands and forces the water out of the filter.
    Open the air bleed on top of the filter with the pump running until the air is all gone. The problem should go away. If it reappears, you need to find out where the air is getting in. Failure to fill the vacuum hose before connecting it? Low water level? Suction side air leak? Could be any or all.
    Oh, and welcome!
    Apr 2014
    Kansas
    9
    Re: Backup problem
    Sorry, I didn't mention I'd already tried that. All the air is out when I start the pump. It's only after I shut it off that it gets full of air. I bleed off all the air before starting the pump again.
    I should also mention I haven't run the vacuum yet this year. Plenty of water, a little on the high side, and I'm not sure what you mean by suction side air leak?
    And thank you for the welcome. Been a member for awhile, but this is the first time I've had a problem I couldn't find the answer for.
    Richard320's Avatar
    Jan 2010
    19,052
    Re: Backup problem
    Air is entering somewhere while the pump is running? That's a suction side air leak. There's an article in pool school.
    Apr 2014
    Kansas
    9
    Re: Backup problem
    Could it possibly be something hooked up wrong? I can't figure out what it could be, but it wouldn't be the first time. And where might the possible air leaks be? Everything's tight, no holes in any hoses.
    30,431
    Re: Backup problem
    Start with the Suction Side Air leak article in Pool School. That'll define the suction side to you and you can start to eliminate some things. These leaks are often hard to find but very easy to fix when you do.
    Apr 2014
    Kansas
    9
    Re: Backup problem
    I read it and based on that, went and got a new O-ring for the pump basket. I wasn't very pleased with the fit of it though, it was a lot looser than the one I took off. But I ran it a couple minutes and it didn't back up when I shut it off. I'll probably know for sure tomorrow. One of the workers there seemed sure it was the sand that either needed cleaned or replaced. So I also got the chemical to clean it if necessary.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Backup problem
    What chemical? This is how we recommend to Deep Clean a Sand Filter
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,620
    Re: Backup problem
    Did you put o-ring lube on it?
    Take back the stuff they sold you and do the above ^^^^^
    Kim
    Apr 2014
    Kansas
    9
    Re: Backup problem
    Quote Originally Posted by pooldv View Post
    It's called Kleen It by Bioguard. I read that, haven't had to do it yet.
    Quote Originally Posted by kimkats View Post
    Kim
    Yes, I put lube on it too. Thanks.
    30,431
    Re: Backup problem
    That's just plain ignorant advice. I would not listen to another thing he says...period.
    Apr 2014
    Kansas
    9
    Re: Backup problem
    Apparently it was, because the new O-ring on the pump basket lid seems to have done the job. Still worried about the loose fit of it though. I'm sure it's getting pinched when I tighten the lid down. I can see it becoming a problem again soon.
    Apr 2014
    Kansas
    9
    Re: Backup problem
    Well, that WAS soon. Already started doing it again. Same as before. I still think I'm on the right track because it was pretty good for a few days. But if not, how likely is the leak to be in the small plug under the pump basket? It seems to have silicone around it so I didn't take it out to check it.
    Richard320's Avatar
    Jan 2010
    19,052
    Re: Backup problem
    Quote Originally Posted by Merrick View Post
    That's the drain plug for winterizing. They have an O-ring under the integral washer, If someone's got it all globbed up with silicon, there's probably a problem with that one, too.
    Apr 2014
    Kansas
    9
    Re: Backup problem
    I bought it new, that's just the way it came. I'm not sure it's silicone, but that's what it feels like around it. Do you think I need to revisit the basket O-ring then?
    Apr 2014
    Kansas
    9
    Re: Backup problem
    After buying yet another new O-ring, which was apparently too small, I ordered 3 new ones from 3 different sellers. The first one that came seemed to do what the others were supposed to. I haven't had any more geysers when I shut it off. I also had the valve on the filter taken apart and a new metal washer put on where a plastic one had a chip in it. That solved the leaking around the top of the valve.
    Thanks so much for all the ideas from everyone. I really appreciate each and every one who helped me.
