Thread: Backwash question
    May 2016
    Central Valley/ CA
    28
    Backwash question
    I have a Jandy 580 CV cartridge filter and recently plumbed a valve in place of the solid drain cap at the bottom of the filter. Would opening this valve while the pump is running "backwash" the filters?
    35,049 gal in ground free form pool, Jandy CL580 Cartridge filter, Jandy SHPF2.0-0 pump, Chlorine
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Re: Backwash question
    No, that would be more of a waste setting. The drain is on the dirty side of the filter. So all you'd do is pump water out of the pool, through the pump and out the filter drain.
    Backwashing is flow reversal. You can't do that with a cartridge filter.
    May 2016
    Central Valley/ CA
    28
    Gotcha. There have a been a few times where I have had to vacuum when it was extremely dirty. By opening the valve, would it be "vacuuming to waster" and sending all that was vacuumed up directly out?
    Richard320's Avatar
    Jan 2010
    18,985
    Quote Originally Posted by tobydog View Post
    Most. Maybe all, if the filter was really dirty. It just depends on the resistance on each path -- out the drain or through the filter and back to the pool.
    If you're vacuuming up big gobs of stuff, remember it can clog the pump basket and/or slip through and clog the impeller. The basket's easy to remedy. The impeller, not so much.
