Results 1 to 9 of 9
Thread: Goldline GVA-24 Actuator failed
    Sep 2015
    Tampa, FL
    23
    Hi folks,
    I have a Goldline GVA-24 valve actuator which controls a valve that turns off/on water going to a spillway.
    The actuator is connected to a Pentair Easy Touch 4 control system. The actuator has stopped working.
    The actuator electrical cable (3 wire) is connected to the “valve B” actuator 3 pin connector on the Easy Touch Controller. Upon removing the pin connector at the Easy Touch Controller I used a multi-tester and determined I am getting 24v at the pin connector from the white and black pins when the spillway button is on and 24 v on the black and red pins with the spillway button off. I believe this is normal so I’m going to conclude the Easy Touch Controller is not at fault.
    I noticed that the actuator motor while I was doing this testing got very hot.
    It appears the fault is with the actuator. Can this actuator be repaired and is there any testing of the actuator than can help in determining why it has failed?
    Tim
    10,000 gal concrete pebble tech
    SWG. 8 yo, Cartridge filter
    Pentair single speed pump, Solar Heat
    Tampa, FL
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Re: Goldline GVA-24 Actuator failed
    I just replaced one. Mine was activating but with high pitch whine. I took the top off and the motor was seized. I ordered a replacement (exact match but new), After I paid full price I found intermatic has drop replacement for half the price. I have ordered 2...we shall see if they are as dependable..
    R
    Sep 2015
    Tampa, FL
    23
    rbinn, can you post the web site for the intermatic unit you ordered? How did you determine the motor was seized? I guess there is no replacement parts for these valves.
    Does the intermatic have the same 3 pin connector as the Goldline?
    Tim
    Tampa, FL
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    I'm away from home till later today but will post tonight.
    R
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    timjet,
    Here is what I ordered, it looks exactly the same: Intermatic PE24VA 24-Volt Pool/Spa Water Valve Actuator: Amazon.ca: Patio, Lawn Garden
    The plug for the board is attached as the replacement GVA24 was. It's going to take me a bit to test so no feed back yet. Time will tell. It was 156.07 to my door. The GVA24 through a dealer was 268.80.
    Cheers,
    R
    9 x 18 Hydro Force AGP, Aqua Pro AP ASFAL 75 pump and sand filter, Hayward Skimmer, Raypak 106A propane heater, Sunquest Solar Panels, Pentair Rainbow test kit.
    Sep 2015
    Tampa, FL
    23
    Thanks R, I was hoping to get repair parts. I'll try the intermatic.
    Tim
    Tampa, FL
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    The Intermatic one will work with any automation system that uses the 24v actuator. I've used the Intermatic one several times as a replacement but I do not like them as much. Doesn't seem as solid or quick as a Pentair or Hayward.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Hi ps0303,
    What kind of lifespan did you get?
    R
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Well they are still in use to my knowledge. Installed about a year now. I only used them twice but went back to the Hayward and Pentair brands for any future installs.
    Paul
