Thread: Orientation of Return Jets
    Apr 2016
    Houston, TX
    60
    What should be the orientation be of my return jet fittings? I have 4 return jets with 3/4" eyes, a waterfall, and 2 skimmers. Waterfall and return jets are both full open at all times. Main drain does not work.
    Thanks
    IG, Plaster, 15,000 gal, Free-form (angular)
    Pentair FNSP 48 DE filter (48 sqft)
    Hayward SP3010X15AZ pump with 1.5 HP motor (installed 3/2015)
    Rock waterfall, large live oak shades half the pool
    Re-plastered April, 2017
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Orientation of Return Jets
    the answer is "it depends"
    Buy a pack of ping pong balls or the shipping peanuts and throw them in the pool..
    Watch and see what they do, if they bunch up in a corner move the eye around to get better flow
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    Empty water or soda bottles with the caps back on them also make good floats to test the water currents.
    Apr 2016
    Houston, TX
    60
    Do we need to try to consider current below the water surface also? Is there some rule of thumb (i.e. all facing downward to bottom of pool, or all facing up)?
    Richard320's Avatar
    Jan 2010
    19,073
    Not for skimming action. Ideally you can find some way to get water moving downwards as well, so you don't end up with temperature stratification.
