Thread: AGP center drain?
    AGP center drain?
    Hi all, I have a probably easy question for the veterans out there.
    I have a 24' x 4' round pool, installing a new overlapping liner on it. My question is that my pool has a center drain, and I am a little foggy on how to install the liner on to that. Is the drain even really necessary? Could I not just remove and fill the hole and eliminate the piping and go on with my life not having to worry about it?
    Jun 2014
    14,970
    Re: AGP center drain?
    Hello and welcome to TFP. Can you operate without a MD? Sure. Many do ... I don't have one. In fact, many feel that surface movement and skimmer removal of debris is more important for their pool. Just make sure you have good return jet circulation to your skimmer and you'll be fine.
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    In my opinion, having a main drain on an above ground pool is optional. On an inground however, they really help the circulation in the deepest parts of the pool. With an average depth of 40-50 inches however, a skimmer and one return work just fine. If you install a main drain you will also have to properly winterize it. Keep that in mind.
    Above Ground 30' by 54" 22,600
    Hayward S244T Sand Filter w/ 1.5HP Dual Speed Hayward Powerflo Matrix Pump
    TF100 Test Kit
    BBB ALL the way!
    Questions about pool care? Visit Pool School
    30,402
    Nix the main drain for me. Like Blake1989 says, an IG pool may be a little different but I see no real purpose on an AG pool
    mariane's Avatar
    May 2012
    Southeast Michigan
    299
    We have a deep end with a main drain in our 16 x 28 AGP and do not use it very often. It did not seem to make much difference for keeping the pool clear. With that said, it does come in handy when/if you want to circulate the water while swimmers are in it. If the water level goes below the skimmer line such as when draining and still wanting to circulate the water this is handy. Also, the debris from the deep end goes directly to the pump thru the main drain and not thru the skimmer which, for us, has the skimmer sock and blocks a lot of the small debris. If we had to do it again, I think we probably would NOT install one.
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 6 years and counting. In sunny but fickle metro-Detroit.
    Casey's Avatar
    SW PA
    10,421
    Get rid of it. I'm of the opinion that the less you cut the liner the better off you are to avoid leaks.
