Results 1 to 9 of 9
Thread: Intellichlor temperature compensation
    The IntelliChlor tends to have problems with temperature compensation. I think that itís most likely due to an unreliable temperature sensor.
    I think that the sensor tends to drift away from the true water temperature over time, in many cases. If the water temperature measurement is off, the salinity will be off as well with the salinity error being proportional to how inaccurate the temperature reading is.
    If the sensor reading goes outside certain limits, the system will assume that the temperature sensor has failed and it will use 77 F as a default water temperature. In that case, the error will depend on how far the water temperature is from 77 F.
    Part of the problem is that the Intellichlor does not report cell temperature, even with automation. If it did report cell temperature, one could detect and resolve problems quickly.
    Support the site
    JoyfulNoise's Avatar
    May 2015
    13,247
    Re: Intellichlor temperature compensation
    The only way to get system information from the IntelliChlor is to purchase an IntelliWand -
    Amazon.com: Pentair 520594 Diagnostic Wand Replacement Pool/Spa Sanitizer and Automation Control Systems: Patio, Lawn Garden
    It's really infuriating that Pentair does this but I suppose it's designed that way to keep the service channel closed to DIY types. They also removed the field calibration method from the IntelliChlor units after version 2.0 because too many untrained "professionals" and owners would mess up the calibration.
    Matt
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,758
    I get a salinity and temperature reading from the IntelliPH. Often times, the temperature varies from what the EasyTouch reports so perhaps the temperature reading is coming from the cell?
    A person without automation wouldn't have a temperature probe in the plumbing, yet the IntelliPH would still report salt and temperature. The reading must be coming from the cell then.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    May 2015
    13,247
    Quote Originally Posted by bdavis466 View Post
    Most commercial pH probes will sense temperature as well so that they can compensate the voltage drift of the pH reading with temperature. The IntelliPH is likely just reading the temperature at that point.
    Matt
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,758
    There is no pH probe on the IPH. The only place that information can come from is the cell.
    -Brian-
    POOL BUILD
    Cell Status
    This menu allows you to view the current salinity and temperature of your pool as provided from the IntelliChlor cell.
    http://www.pentairpool.com/pdfs/intellpHOM.pdf
    Interesting, I did not know that.
    Support the site
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,758
    There are a couple features like that on the IPH. It also allows for adjusting the IC in 1% increments similar to the ET which would be very welcome for those without automation. Beyond these minor conveniences, the IPH as a whole is not very intelligent at all.
    -Brian-
    POOL BUILD
    May 2015
    13,247
    It's interesting to me that there is so much communication going on between the IC, IPH and ET panel and yet the folks at Pentair can't even send back data from the IC on current, voltage, cell runtime, etc. The data is there, Pentair just refuses to make it accessible.
    Grrrrrr.....
    Matt
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,758
    Its also too bad the brain and electronics are built into the cell where a thin piece of plastic is all that protects it from a pressurized water stream on the opposite side. I can't imagine it would be difficult to build that portion of the electronics into the transformer and/or the EasyTouch panels.
    -Brian-
    POOL BUILD
