Thread: how much sand for bottom coving??
    Aug 2009
    SW Wisconsin
    518
    well got our old liner out, the vertical supports that had sunk a bit, raised back up..I Now NEED to add in, some sand coping in areas that lost some due to washout. Is there a calculator, or can someone just tell me...how much mason sand will I need to redo the sand coping in my 33ft diameter AGP? I am assuming a 6 inch height curved up the wall all the way around.
    Thanks for any help
    Dan
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,490
    Re: how much sand for bottom coving??
    Above Ground Pool - Above Ground Pools - INYOPools.com
    Read this ^^^^ scroll down to the part about the sand cove.
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    33 foot diameter means 396 inch diameter means 1244 inch circumference.
    6" radius means 113 sq inch volume for a full circle. One quarter of that is 28.27 in2 A square 6" on each side would be 36 in2 36-28.27 is 7.73 in2
    7.73 in2 times 1244 in = 9611 in3
    9611 cubic inches is .206 cubic yards or 5.56 cubic feet. In pounds of sand, I don't know.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,778
    1 yard (27 cu ft) of dry sand is roughly 2700lbs. That works out to about 100lbs per cubic foot. So according to Richard you will need about 550lbs of dry sand. If you have a pick up truck and a local supplier masons sand generally goes for about $15 a ton which beats the pants off buying it but the bag at home depot for $5 for 50lbs.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Aug 2009
    SW Wisconsin
    518
    I'm going to pick up a half yard....as probably 3/4 of the old sand coving is still there, just where it washed out is gone....so going to make it 6 inches high all the way around, and go from there.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,778
    Half a yard should be enough for the coping and enough left over to make a sand box for the kids.
    Chuck-
