Thread: 1.5 inch IPEX piping -- what SWG can I use ?
    May 2016
    Thornhill, Ontario,Canada
    3
    Hello,
    I have an 80,000 litre (21000 gallon) pool which is almost 30 years old. The system runs with 1.5 inch "IPEX" pipes (I believe these are PVC but am not sure). I am looking to convert to a SWG, but it seems that the IC40 unit I am looking at connects to 2 inch "PVC" pipes. What are my options ?
    Second question - the previous owner of this house told me the pool is 80000 litres (approx. 21000 gallons). It seems that 20,000 gallon is a standard size, so I'm wondering if the previous owner simply rounded up to 80,000 litres when in fact the pool really is 20,000 gallon. SO, the questions is. do I need the IC40 unit or would the IC20 unit be large enough for my pool ?
    thanks, Ron
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: 1.5 inch IPEX piping -- what SWG can I use ?
    Hi Castelle,
    We would recommend the IC40, or any other cell that is at least 1.5x the size of your pool. Larger cell = longer life.
    As a rule of thumb, the larger the cell the longer it will last, because it doesnt hvae to work as hard.
    As for the piping, you can use the IC 40, use put a reducer between the output of the cell and your existing pipe.
    Divin Dave,
    Apr 2013
    Sacramento, CA
    2,769
    Go to the plumbing department at Home Depot or Lowes (are there Lowes in Canada?). Explain your problem and they will either sell you the correct reducer or direct you to a plumbing supply house that will have it.
    May 2016
    3
    Thanks for the advise.
    I'll also have to use the opposite of a reducer (expander ?) to connect to the input of the SWG (from 1.5 inch up to 2 inch). Will this change of diameter cause any problems for the SWG ? (possibly due to uneven flow of water ?)
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Using an elarger on the input side wont cause any problems.
    People do the same as you need to all the time and there isnt any worries at all.
    Divin Dave,
