Results 1 to 10 of 10
Thread: First Water Test
    Mar 2016
    Albuquerque, NM
    19
    First Water Test
    This is an awesome site. I have learned so much in a short amount of time. This is a brand new build and I'm a first time pool owner. I tested my water for the first time with the TF100 and here are my results:
    pH - 8.2
    FC - 3.5
    CC - 1.5
    TC - 5
    CH - 350
    TA - 130
    CYA - 40
    I know I should have a CC of <0.5 so I'm confused why it's so high. The pool was plastered and water added starting on 5/11. Any comments are appreciated. Thanks in advance.
    16K gal, IG, plaster, Hayward TriStar VS Pump, Jandy CL580 Cartridge Filter, Raypak 266 Heater, Pentair WhisperFlo single speed Water Feature pump, Stenner Liquid Chlorine pump, Zodiac MX-8 Suction Side Cleaner, Automatic Pool Cover, TF100 Test Kit w/Speed Stir
    Donldson's Avatar
    NW Ohio
    2,898
    Re: First Water Test
    Welcome to TFP!
    You will probably be battling your pH for a time while the plaster cures, so make sure you have a couple gallons of muriatic acid on hand. Your CC is quite higher than we would like to see. Have you added anything to the water other than chlorine and acid? Any type of plaster start-up chemicals by chance?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mar 2016
    Albuquerque, NM
    19
    They added muriatic acid, a bottle of Regal Metal Out, a bottle of Regal Algaecide 60 and some liquid instant conditioner once the pool was full. Nothing has been added since.
    30,421
    Yeah, we need to get the CC's down a bit. What does your water look like?
    Mar 2016
    Albuquerque, NM
    19
    The water is clear.
    30,421
    The water is clear.
    In that case, I see no reason for you to SLAM. We need to get the CC's down but I think you can do that with an elevated increase in your chlorine.
    1. First, drop the pH to around 7.4 using muriatic acid.
    2. Next elevate you FC to about 8 ppm and hold it there. I believe that extra chlorine will reduce your CC's in just a day or two to .5 ppm or 0 ppm.
    3. You can "tweak" your other numbers if you like but adjusting your pH and getting rid of the cc's is all you need.
    If you have been covering the pool, take the cover off.
    Mar 2016
    Albuquerque, NM
    19
    Added chlorine last night and when I tested the water about an hour later my was FC to 8.5 and CC was 1. I tested the water this morning, my FC was 7.5 and CC was 1. My pH was 7.4 both times.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I would keep FC up around 8 or 9 for a bit to burn off the CC and see what happens.
    Mar 2016
    Albuquerque, NM
    19
    Quote Originally Posted by pooldv View Post
    Been keeping my FC around 9 and this morning when I tested, my FC was 9 and CC was 0.5. Should I still keep my FC at 9 until I get a CC of 0 or am I good to go?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,074
    If the water is crystal clear you are good! Good job!
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
