Thread: TF 100 or Taylor K 2006c
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Hello everyone!
    Currently I own the Taylor K 2006 c and starting to run out of some (not all) reagents.
    I am reading here and there and notice that the one that is most recommended is the TF 100.
    I am thinking about switching to the TF 100 xl. Do you think it is worth it? Or it is really not necessary?
    Thank you all in advance!
    15K gallons, Plaster, Taylor K-2006C & TF-100, DE, non SWG, Hayward TriStar VS variable pump
    Aug 2014
    Northern IL
    4,615
    Re: TF 100 or Taylor K 2006c
    Just get new reagents. It's cheaper.
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    For folks buying from scratch, I always prefer the TF-100 if they have larger pools or problems to deal with. That kit comes with more of the reagents you'd actually use and need the most.
    But since you have the box and such, perhaps just buying replacement reagents is the way to go? If you want to get creative get a set of replacement reagents for the TF-100 (be aware that the pH tube uses different reagents in the TF-100 than the K-2006) and put together your own personal kit.
    Fishing tackle boxes make handy test kit organizers when folks want to expand their original kits up a bit.
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Quote Originally Posted by MarianParoo View Post
    Thank you!
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Quote Originally Posted by YippeeSkippy View Post
    Thank you for the information.
    38,248
    Tftestkits.net sells all the reagents and has refill kits for the k2006. Note the TF100 uses Taylor reagents that almost all are identical to the k2006.
