Thread: Tear in plastic bottom of Pentair Clean & Clear 200
    Nov 2013
    North-Dallas Texas
    18
    OK every time I buy a new filter within a month the plastic tears at the bottom of the filter. The top doesn't unless I turn the filter over the other way.
    Am I doing something wrong in installing the filter or the pvc center section that holds the filter? My pressure gauge seems find its between the 2 arrows. Do I need to clean the filter more often?
    These dang filters are expensive and when busted don't clean out the pool as well.
    Thanks for your help.
    15K Gallons IG Plaster Pool 7-9 hours of sun, Pentair WF-28 2HP pump with Cartridge Filter with Pentair heater
    Polaris 280 cleaner
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Tear in plastic bottom of Pentair Clean & Clear 200
    What is your pressure?
    those 2 arrows are 90% of the time wrong, we recommend to clean your filters when the pressure rises 25%
    If your pressure is at 10 you would clean the filters at 12/13 psi
    This type of pressure guage makes it much easier to see when you need to clean TFTestkits.net
    Nov 2013
    North-Dallas Texas
    18
    I just read this. But don't know if my system is Plumbed backwards.
    PLUMBED BACKWARD
    When a cartridge is used in a canister through which the water flow is reversed, or “plumbed backward,” debris will collect between the filter media and the center core of the element. Accumulated debris plugs up, or “blinds off,” the media such that the water will not flow properly and pressure will build up inside the filter cartridge. Eventually, the pressure increases to the extent that the end cap(s) crack to release the pressure.
    Unless the water flow is corrected, this failure will continue. Your customer should be notified immediately so that corrective action can be taken before another element is installed.http://www.unicelfilters.com/swimmin...trouble_06.gif
    Polaris 280 cleaner
    Nov 2013
    North-Dallas Texas
    18
    Just checked the bottom of the filter on the outside. It says inlet and outlet and guess what, they are reversed. Son of a biscuit, it's been like that for 4+ years and I've always wondered why my dang pool doesn't clean as well. I've been using the filter in the skimmer to add a layer of filtration. Guess I have a new project on my hands.
    Polaris 280 cleaner
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,511
    Wil,
    That was my first thought, but I figured that likelihood of that happening was so low that I would look like an idiot for suggesting it. Now I look like an idiot for not suggesting it.
    Good catch.. Glad you got it figured out.
    Jul 2013
    Fletcher, OK
    3,353
    I never would have thought that, new one to put in the memory banks...
