Results 1 to 7 of 7
Thread: Low sal & Check Cell light
    Jul 2010
    Longwood, FL
    151
    I had salt reading of 2200 , added one bag reading went to 2300 , added another bag reading show 2500
    1. Cleaned the filter
    2. Cleaned the cell in water + muratic acid
    3. Did set the reading (Auto, OFF , 5 times , Super Chlorinate , auto)
    Now the display say 2500 as salt & Low salt & inspect cell light are flashing RED
    Any clue
    Note: Cell is about 4 yr old)
    15,000 Plaster IG Pool
    AquaRite SWG, C1750 Catridge filter
    G3 Vaccum, T-100 Kit
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Low sal & Check Cell light
    The cell could be failing. Do you have a Taylor salt test kit to confirm salt level?
    Mark
    Jim's Pool's Avatar
    Aug 2015
    Staten Island, New York
    1
    What is your water temperature?? As the water temp effects the reading, I have experienced that issue in previous year. Check your cell manual and it will give you a minimum temp for a stable reading. I have a Pentair
    mas985's Avatar
    Pleasanton, CA
    11,737
    Intellichlor is notorious for having very poor temperature compensation for salt level readout. However, the OPs unit is AquaRite which is pretty good at temperature compensation over a wide range of temperatures until the cell starts to fail.
    Mark
    Jul 2010
    Longwood, FL
    151
    hi water temp is around 85
    regards
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by mas985 View Post
    Did you miss this question?
    Mark
    Three most likely reasons
    1) Salt level too low.
    2) Cell wearing out.
    3) Wrong cell type selected.
    What are the diagnostic readings?
    Which cell do you have (T-3, T-5, T-9 or T-15)?
    What is the actual salt level as tested by the Taylor K-1766 salt test kit?
    Support the site
