Results 1 to 12 of 12
Thread: First results after adding Salt
    Apr 2015
    Boston MA
    93
    Hello folks,
    So it's been a week since I added salt. Here are the results below.
    FC-2.0
    CC-Zero
    TC-2.0
    CH-50
    TA-140
    CYA-80
    PH-7.8
    CL/BR-Zero
    Salt-2800ppm
    Last Sunday I added (6) bags of Morton salt from Walmart. I have the Intellichlor SWG set at 80%...model IC15.
    Should my FC be this low? Is this a direct result of the SWG replacing the chlorine?
    I'm headed over to Poolmath now to see what's missing.
    Thanks all for your valuable input.
    P.s. the water is very clear...
    12,000 Gal,IG Vinyl,Pentair 1HP Dynamo,Pentair SD40,Pentair Intellichlor SWG,Dolphin Nautilus, TF-100
    15x30 Oval 13,500 Gal, IG Vinyl built Fall 2015,
    TF-100 test kit
    Pentair Sand Dollar 40 Pump & Filter System 1HP Dynamo
    Pentair Intellichlor SWG, Dolphin Nautilus
    Apr 2015
    Boston MA
    93
    Re: First results after adding Salt
    OK...just did Poolmath.....
    Looks like (2) 40lb bags of Salt to achieve levels of 3500ppm and 60oz of Chlorine @8.25%?
    Does this sound correct everyone?
    Thanks for your help.
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Seems about right. If the FC was low when you fired up the SWG, it will take a while to build. Give it a hand with bleach and then try raising the SWG% or the pump run time so it produces a little more.
    Apr 2015
    Boston MA
    93
    Thanks Richard. I just added the chlorine. Time for the Salt now.
    I'll dial in the SWG to 100% and keep the pump running for 9hours. Test levels again maybe Wednesday?
    Lastly, I have not backwashed during this whole process...running at 100psi
    TF-100 test kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by derryank View Post
    I hope that was a keyboard misprint and you're not at 100 PSI, maybe 10??
    Apr 2015
    Boston MA
    93
    Quote Originally Posted by cowboycasey View Post
    Very good Cowboy...my bad...10psi is correct. Good catch
    TF-100 test kit
    Apr 2015
    Boston MA
    93
    Hello folks,
    So here are the results from this evenings test below. As suggested on Sunday, I added the chlorine and two bags of salt.
    FC-3.5
    CC-Zero
    TC-3.5
    CH-50
    TA-130
    CYA-70
    PH-7.8
    CL/BR 3-6
    Salt-3800ppm
    The CYA has dipped a little. I was hoping that the FC would be slightly higher.
    Any suggestions? Planning on having quite a bit of activity in the pool this weekend....at last!!!
    I think the numbers are swimmable? Would love to hear your thoughts.
    Thanks....P.s. my TFP shirt arrived today-i'll proudly display it this weekend at the pool parties!!
    TF-100 test kit
    May 2015
    Land O Lakes, FL
    527
    For the weekend, you could bump up the FC with bleach.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Apr 2015
    Boston MA
    93
    Hi Richard-I just followed one of your link on another thread about SWG and CYA...WOW-i've a severe headache...
    That said-my take away is, there is a fine line between CYA and FC levels combined with the SWG output. Specific to each pool is what I'm getting at.
    I'm satisfied with the current levels in the pool. Just wanted to hear your feedback.
    TF-100 test kit
    Aug 2010
    Dallas, TX
    4,052
    Plain Solar Salt for water softeners is a little cheaper, just a hint.
    Diamond Crystal Solar Salt 40 lb. Extra-Coarse Water Softening Salt-100012454 - The Home Depot
    Apr 2015
    Boston MA
    93
    Thanks Robbie...this is similar to what I purchased.
    Appreciate the tip
    TF-100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Quote Originally Posted by mgmoore7 View Post
    +1, I always add a jug of bleach before and after big swim days, and sometimes in the middle if there are kids swimming ALL day. A jug of 8.25% bleach adds 4 ppm FC to my pool. And remember that it is safe to swim with FC up to shock level for your CYA. We swam for a couple of weeks last summer with FC at 28 ppm and nobody even noticed. Chlorine is your friend. I've had the solar cover on the pool warming it up for the weekend and it's been cloudy so my FC is up to 15.5 ppm this morning. Just about right for the 85-88 degree sunny mega-swim days that are about to happen this weekend.
