Results 1 to 9 of 9
Thread: Pump isn't keeping a steady psi
    Apr 2010
    Central Illinois
    205
    Hi everybody!!
    We Opened pool, got everything hooked up, and started it up. The pump is pulling water in fast then real slow. When it's slow I open air valve on filter and it fixes it for a minute, but then continues to go back and forth.
    Any ideas on what could be wrong?
    Thanks in advance
    15x30x54 AquaLeader Sentinelle AGP
    2 HP 2 Speed Hayward SwimPro Voyager Pump
    Hayward SwimPro Voyager 150 sq. ft. Filter
    Hayward H series millivolt 150 btu Heater
    TF-100
    Houston, TX
    1,104
    Re: Pump isn't keeping a steady psi
    how old is your pump? Is it under warranty?
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    Apr 2010
    Central Illinois
    205
    Just got it last summer.
    TF-100
    mas985's Avatar
    Pleasanton, CA
    11,741
    Is air getting into the pump basket? It could be a stuck weir or pool water is too low.
    Mark
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Quote Originally Posted by mas985 View Post
    My thoughts exactly. It's surging.
    Pump primes, starts moving water really well, empties the skimmer or creates a vortex, sucks air, lose prime, skimmer refills, pump primes again.... Repeat every twenty seconds or whatever.
    The cure is to make sure the skimmer weir (flapper) isn't stuck and that the water level is high enough.
    Apr 2010
    Central Illinois
    205
    I'm putting more water in now. I'll try again in a bit and let ya know.
    Thanks!!
    TF-100
    Apr 2010
    Central Illinois
    205
    That worked!!!! Thanks
    TF-100
    Richard320's Avatar
    Jan 2010
    19,052
    Quote Originally Posted by oasis1 View Post
    That just saved you a hundred dollar service call.
    Apr 2010
    Central Illinois
    205
    And I can't thank you enough !!!!
    TF-100
