Thread: Suntouch Controller
    May 2016
    Scottsdale/AZ
    1
    Suntouch Controller
    Looking for some help on my Suntouch controller. I appreciate any assistance...
    It is currently working fine but I can get it to control my waterfall. I HAVE TO UNPLUG THE BLOWER RELAY IN "AUX2" AND PLUG IN THE WATERFALL RELAY TO "AUX2" TO GET IT TO WORK.
    Here is what I have currently:
    VS Pump wired to relay that is connected to "Pump" on control board.
    Blower wired to relay that is connected to "Aux2" on control board.
    Waterfall pump wired to relay not connected to anything on the control.
    The one valve actuator is wired to "Return"
    I need to control the following:
    Cleaner
    Spa
    Blower
    Waterfall
    Pool Light
    Brad Cooper
    In Ground Pebble Tech Spool (1 body of water)
    In floor cleaning, Spa Jets, Blower, VS Pump
    Waterfall with dedicated pump
    Apr 2013
    Sacramento, CA
    2,769
    Re: Suntouch Controller
    Casey's Avatar
    SW PA
    10,448
    Can not help but if like to welcome you!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    I am not familiar enough with the Suntouch and I know the manuals aren't easy to follow. But, Pentair is very helpful with configuring their pool automation. Give them a call.
