Results 1 to 7 of 7
Thread: Question about electrical install
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    If it ever stops raining the digging can begin soon
    I'm getting a 2sp. 1HP tristar pump,425 cart filter, and Agua Rite SWG. Should the pump and SWG be hooked up in any special way?? I would think that the SWG shouldn't have to run everytime the pump is running.
    Do you switch speeds of the pump on the pump or do you actually have a switch in the electrical box??
    Also, the equipment pad will be at the end of the pool,away from my house. Should I have any switches at the house to control anything at the pad??
    Thanks
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Re: Question about electrical install
    If you really want to control the pump from the house, you should get an automation system. That can give you remote controls where ever you want them.
    I like to wire up a separate switch to control the speed. If you get an automation system, it can control the speed.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Thanks Jason. I don't think an automated system is in the budget.
    Lynn
    Round Rock, TX
    529
    You can get a pool timer that will switch the two speed pump for you. I really like the one I have (see sig). This lets me run on high for a few hours to run the cleaner, then on low with my SWG turned on for several more hours each day for filtering and chlorine generation.
    I like it a lot and it's not too costly.
    dave
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Thanks guys. The timer might be the route I go.
    Lynn
    Jun 2008
    Scottsdale, AZ
    37
    If you already getting an Aqua Rite why not spend a little more ($200 or so) and get the Aqua Plus? That gives you the SWG and the automation.
    Gary
    18 x 38 28800 gals gunite inground;Purex Triton High Rate Sand Filter;1 HP 2 Speed Hayward Tristar Pump; Raypak Heater
    Aquabot Bravo; Goldline Aqua Logic Controller/SWG
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    I'll check into that. Didn't realize there was only that much difference.
    Thanks
    Lynn
