Thread: Raypak 2100 Heater Won't Ignite
    May 2016
    Madison, WI
    1
    I have a Raypak 2100 heater that won't ignite. Worked fine last year, I replaced the board last July. It turns on fine now, sparks, but then pilot doesn't ignite. It's as if it isn't getting gas. Valve is on, seems like orifice might be blocked. My question is how to get to the pilot to disassemble it? Do I need to take out the whole burner drawer? The pilot is behind a bracket that is I can really get to to unscrew. I realize this heater is getting to the end of its life but trying to get another season or two out of it. Thanks!!
    ps0303's Avatar
    Jul 2011
    FL
    3,682
    Re: Raypak 2100 Heater Won't Ignite
    When it's sparking, carefully look under inside to see if the pilot lit or not. If it is not lit, try using a long BBQ lighter to lit it while it is sparking. If this is a propane unit, wait a few minutes before you try to lit it just in case you have a pool of gas from the the last attempt. No you do not need to remove the burner tray to get to the pilot but I wouldn't go removing it right now.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
