Thread: new build - cement stuck to liner
    May 2016
    HUntington, NY
    13
    Hi. My name's Mike and I'm from Long Island NY. I've had a new vinyl pool installed (cement sides) and the masons that installed the bluestone coping let a lot of mortar fall into the pool. In addition to trashing the grids on my new filter, it seems that the pool service company is so far unable to remove some sizable pieces of concrete that collected in the corners and seams. They are concerned that being aggressive will tear the liner.
    This is my first pool so I'm just barely getting up to speed with everything. I'd love to know if anybody else has experienced this and would welcome any advice to solve the problem.
    thanks!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: new build - cement stuck to liner
    Welcome to TFP
    If the pool company did this it's easy... tell them you want a new liner.
    Unless you wanted concrete on your liner, but for some reason I don't think that was something you asked for when you hired them
    May 2016
    HUntington, NY
    13
    Thanks. Just to follow up, I gave each piece of concrete a bunch of LIGHT taps with the end of the brush pole and the flex seemed to crack the concrete so most of it came off. still a few spots I hope will lift off in the coming weeks.
    Jul 2013
    Fletcher, OK
    3,353
    Nice job, as long as your happy is all that matters
