Thread: What is the correct pump and filter size needed
    May 2016
    Exira, iowa
    3
    I am replacing the pump and sand filter that came with my intex 16x32 ag pool. My pool holds about 16,000 gals. The pump is cracked and leaking and didn't really work very well from the beginning. After some research I have thought about purchasing a 1 1/2 hp Hayward pump with the medium sized cartridge filter. Although it's a bit more than I wanted to spend, as long as it's what my pool needs to stay clean, it's worth it. I need to know if this is the correct system for my pool. Also does anyone know if I will need to purchase new hoses that go to and from the pool or will the existing ones work? There are so many options out there and it's been a bit overwhelming, to say the least! Ha! Thank you!
    I filled my 16,000 gal pool and expected the new pump to be delivered the same day. Five days later no pump and a very green pool. Do I have to drain the pool and start over or is there another way. The pump is supposed to be here tomorrow.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: What is the correct pump and filter size needed
    Welcome to TFP
    That pump is pretty big and a power hog for what you need... We love to do 2 speed pumps as it will use 1/3 of the power on low and pump 1/2 the water, win win...
    most people stay with the intex pumps but just go to a bigger pump, sand filter, and SWG like this.. this system will be easier because the SWG is creating chlorine for you.. it is right at the 15k gallons so it will work but not very good, probably not what you want...
    Amazon.com : Intex 120V Krystal Clear Sand Filter Pump Garden
    This one is the bigger pump and filter
    http://www.amazon.com/Intex-Krystal-...rds=intex+pool
    You can go to a hard pipe pump and filter, (that is what I have) bigger is better for filters and pumps you want in the 3/4 hp to 1hp range
    Amazon.com : 1 HP 2-Speed 3450/1725 RPM, 115 volts Above Ground Pool Pump - Waterway brand - With large Debris Ba : Swimming And Pools : Patio, Lawn Garden
    Amazon.com : Hayward S180T Pro Series 18-Inch Top-Mount Pool Sand Filter : Swimming Pool Sand Filters : Patio, Lawn Garden
    If you want 1 system here is a 1 hp with 19 sand filter that would work good
    Amazon.com : Best Choice Products® Pro Above Ground Swimming Pool Pump System 4500GPH 19 Garden
    With all that said, I have the same exact pool and went with this setup, it has no issues at all but I did add a SWG to it..
    Amazon.com : Pentair 340042 SuperFlo High Performance Energy Efficient Two Speed Pool Pump, 1 Horsepower, 230 Volt, 1 Phase - Energy Star Certified : Swimming Pool Water Pumps : Patio, Lawn Garden
    Amazon.com : Pentair Clean and Clear Plus 320 Square Foot In Ground Cartridge Pool Filter - 160340 : Swimming Pool Cartridge Filters : Patio, Lawn Garden
    CircuPool® SJ-40 Salt Pool System
    Here is my build thread, on page 2 you can see how I piped it in, if you want this type of setup it is really easy once you get into it
    New above ground oval 18x33 install
    The funny thing is I still have the pump and filter that came with this pool in my garage unopened...
    I hope this helps
    May 2016
    Exira, iowa
    3
    Thank you!
