Thread: Pentair Intellebrite lights controlled by Jandy Aqualink RS? Is it possible?
    Jan 2012
    Las Vegas, NV
    9
    My pool automation is a Jandy Aqualink RS One Touch. The lighting in my pool is a pair of Pentair Intellebrite lights. On/Off is controlled by the Aqualink but, to change the colors of the lights etc I need to turn them on/off and make lighting adjustments as one would with a regular wall switch.
    Does anyone know any way to gain full control of the Pentair Intellebrite lights through my Jandy Aqualink RS? Perhaps an interface module of some sort?
    Brian
    [center:32ql66cj]15,000 gallon, cartridge filter, IG, pebble pool owner
    (Built-in, spillover spa not in use right now, leaking)[/center:32ql66cj]
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pentair Intellebrite lights controlled by Jandy Aqualink RS? Is it possible?
