Results 1 to 15 of 15
Thread: Just got my TF-100 the results are in. Help!!!
    Jan 2016
    Long island NY
    80
    What's up guys AWESOME SITE!!!!. Well after much reading I finally got my test kit. Did some testing today and here we go. This is a brand new build and I'm a brand new pool owner.
    The yellow and red drop kit for everyday PH chlorine.
    CL 24 PH 7.8
    chlorine drop test 2.5
    CYA was below 20
    TA 90
    Calcium in need to redo.
    Last week water was becoming very green. Pool company came over to finish some stuff and they poured 2 gallons of shock in water without my knowledge or approval. This was prior to my TF 100 arriving. Water is much clearer now but still a bit cloudy and when I brush side walls there is some algae.
    Thougths comments greatly appreciated. Thanks in advance
    20x40 rectangle, 28,500 gallons, Vinyl liner, Hayward cartridge filter VSP, Hayward aqua connect automation, connected spa with overflow, Hayward heater, automatic cover, TF100 kit
    Jan 2016
    Long island NY
    80
    Re: Just got my TF-100 the results are in. Help!!!
    Sorry, this is a SWG set at 2800
    Jun 2014
    15,008
    Very possible you have algae in there now. That's a shame because you need to "SLAM" to remove algae. Are you past your 30-day break-in period with the pool/plaster? Do you have full control of your chemistry, or is the PB doing anything for you?
    Jan 2016
    Long island NY
    80
    They really didnt do anything other than add salt. They said once pavers are done they will be back to show me how all equipment works and do a full clean etc... Not sure what the 30 day break in is. This is a vinyl lined pool. It's had water in it since April 27th
    Jun 2014
    15,008
    Oh good, vinyl. Then the break-in doesn't apply. Then the chemistry should be all you now. They may come back to show you equipment, but I guarantee their training for chemistry won't match TFP. So to remove the algae you need to "SLAM" (link below). Adjust CYA with granular stabilizer to ensure it's a 30 ppm. Adjust pH to 7.2, the increase FC to 12. Follow everything you see on the SLAM page and it will work. In case you didn't know, we increase FC primarily with regular bleach. As long as you have the CYA at 30 in the pool, the FC of 12 is safe. SWGs are no designed to maintain such a high FC level.
    Might be a good idea to update your sig to show the pool as "vinyl" as well.
    Jan 2016
    Long island NY
    80
    Ok, thanks. This is a bit intimidating for me as a first timer, lol
    SO i will buy Muriatic acid to lower the PH (according to pool math)
    Add a conditioner to bring CYA up
    And then add bleach to rise PH to 12 (according to pool math)
    Is that basically it??
    May 2016
    Greenville, SC
    14
    Quote Originally Posted by Bski224 View Post
    You're adding the bleach to get your FC to 12, not the pH. A typo I'm sure, but worth mentioning anyway!
    Outback Southport GLX AGP (18' round - 7,180 gal.)
    Hayward Vari-Flo XL Multivalve
    Hayward Dream Line Sand Filter (150 lb.)
    TF-100 Test Kit
    Jan 2016
    Long island NY
    80
    yes, typo thanks!!
    Jan 2016
    Long island NY
    80
    Put my CYA in sock/skimmer this morning. Do I need to wait a few days till it shows up on test before I can start slam??
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Start SLAM now based on CYA added. CYA will show up on test 24 hours after it is dissolved from the sock.
    Jan 2016
    Long island NY
    80
    Ok I didn't do SLAM due to the fact it was not algae it was some dirt from pavers being installed. Here are my #'s what do you guys think!!! I put in CYA 2 days ago I think I need more but not sure how long I should wait until fully shows up on test.
    FC 1
    CC 0
    TC 1
    CAL 125
    TA 90
    CYA 30
    Thanks again guys your AWESOME!!
    FC 1
    CC 0
    TC 1
    CAL 125
    TA 90
    CYA 30
    By the way water looks clear
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Your FC is too low for your CYA. Print this out and put it where you test: Pool School - Chlorine / CYA Chart
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jan 2016
    Long island NY
    80
    Ok should I add more salt??
    Aug 2010
    Dallas, TX
    4,052
    Bleach. Not salt.
    Jan 2016
    Long island NY
    80
    Ok Thanks
