Thread: Solar cover help
    Jun 2010
    Central Indiana
    92
    Solar cover help
    We live in a wide open area surrounded by fields and tend to get a lot of wind which makes solar covers difficult to keep in place. They always want to blow to one side of the pool or blow off making them not worth the effort. We have a 24 foot round pool. We bought a new cover last year that was heavier 12 mil and it kept blowing off and was hard to take on and off so we purchased a solar roller. The solar roller works great but the cover still blows off. Have already tried putting gallon jugs of water on it to hold in place. Are there any other options?
    I though maybe we could get a smaller cover (maybe 18' round) they would stay in place better and be easier to manage. The 24 footer tends to get caught on the ladder and bunch up which may be why the wind catches it so easily. Would a smaller cover fair better? Any other ideas?
    13500 gallon AG (24' round), 100 sf cartridge filter, Hayward 1hp pump, pool 10-15 years old with recently replaced liner
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Solar cover help
    Why not cut out your current cover to go around the ladder so it lays flat on the water?
    Mark
    Jun 2010
    Central Indiana
    92
    Quote Originally Posted by mas985 View Post
    It's In pretty rough shape and needs replaced anyways
    mas985's Avatar
    Pleasanton, CA
    11,737
    I think you are better off with a larger cover so it comes close to edge so the wind can't catch it as easily. You might try cutting out the ladder are so it stays flat.
    Mark
    JoyfulNoise's Avatar
    May 2015
    13,176
    Maybe you could attach some short lengths of foam core ABS pipe to four corners of the cover so that the pipe sits on top of the cover and then use some small bungee cords to attach it to the pool wall. That way, when the wind blows, the cover may kick up a bit but it won't fly away. Taking off four bungee cords wouldn't add too much hassle to the cover removal/redeployment process.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Agree that cutting it close to the perimeter so that it lies flat on the water should solve the problem. When I was cutting mine a couple of weeks ago it was blowing around but once it was cut to fit flat on the water and just inside the pool edge it stopped lifting.
