Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: List of things I need? Cost cutting essentials
    Mar 2009
    Midwest
    101
    I was wondering if there's a list of what I would need for my pool, I thought maybe I should order it all at once. (Pool specs in my sig.)
    So far I have: bleach, borax I have to find somewhere and buy, baking soda.
    Good to have pH up from the pool store?
    Should I also buy the cover cleaner, flocking stuff, or other chemicals that don't have cheap replacements?
    Good test kit as described on this forum.
    I have a leafmaster and will be getting a leaf rake.
    Will get solar cover and have a reel, and I know these aren't necessary.
    Have a crappy tarp that will suffice for winter covering if I cover my pool.
    I have a pole with a net at the end, but it has a hole in it, so I guess I need to buy another... or how do I fix it?
    I have a Dolphin so that helps.
    Any other essentials I need to think about buying?
    Inground oval approx 17.5' x 35' (with middle of deep end 9'?) so guessing 27000 gallons. Vinyl liner, BBB chlorine. Dolphin. Portable fullsize spa not currently in use.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: List of things I need? Cost cutting essentials
    Is your pump on a timer? That can save you quite a bit in electrical costs.
    Quote Originally Posted by aquamarine
    PH Up is soda ash. Soda ash is available as ARM & HAMMER® Super Washing Soda Detergent Booster. Do not confuse this with ARM & HAMMER® laundry detergent! It is sold in the laundry detergent section of most larger grocery stores and some big box stores. You can also buy it from the pool store, but it costs more there.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    PH UP is the same as Soda Ash, and you should be able to get that and Borax at Walmart or grocery store, look in laundry aisle.
    You should need cover cleaner, flocking stuff, algaecide or anything else. A properly balanced pool won't need anything else. If opening issues are present, usually all it takes is lots of chlorine and POP while letting the filter do it's job.
    I've cleaned my solar cover by just hosing it off and let it dry, the FC levels in the pool should take care of anything else. I assume you mean the solar cover. If you want to scrub it good, just use a diluted bleach solution with water should do the trick.
    Probably replace the net.
    marthas_ear's Avatar
    Mar 2009
    Texas (Central)
    65
    Does the Dolphin eat the fish?
    Sorry, I only have a rubber ducky thermometer....I don't know what a Dolphin is.
    Regards,
    Martha in Texas
    17K gl-15'X34' IG, Fiberglass, Pentair: Intelliflo VS 3HP pump, PAL 2000 underwater lights, DE60 filter, Intellichlor IC 20SWG, Poolvergnuegen Suction Pool Cleaner2009 build date; TC100
    Dolphin is a brand of robotic pool cleaners, made by Maytronics.
    Mar 2009
    Midwest
    101
    Hehe I wish I had a pet dolphin. Of course you'd need a huge pool for a real dolphin. The dolphin is an automatic pool cleaner robot thing. It rolls around and vaccuums up stuff.
    Mar 2009
    Midwest
    101
    Okay great, so my list has borax, soda ash, baking soda, timer, leaf rake and new net.
    Quote Originally Posted by frustratedpoolmom
    Umm... POP?
    Mar 2009
    Midwest
    101
    Okay, good about using diluted bleach on solar cover -- can I use that to clean this crappy black tarp too?
    Mar 2009
    Midwest
    101
    Um, maybe 1 bottle of flocking stuff for now though, so the dolphin can work better? Since I am trying to get my swamp back in shape. First I will fish out a lot with the leafmaster & leaf rake & vaccuum obviously. Well, I hope the flocking stuff is not needed, so I can save more money, lol.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    don't forget a good test kit!
    Mar 2009
    Texas (Central)
    65
    Oh! 8)
    I will add my cleaner to my signature....my automatic cleaner's name is this:
    Poolvergnuegen PVN 2X Suction In-Ground Pool Cleaner
    Regards,
    Martha in Texas
    Mar 2009
    Midwest
    101
    Okay, you win the hard-to-say cleaner name contest. Dolphins are not that pretty but I like mine. It was on the less expensive side as far as those robots go.
    I mentioned test kit
    Jan 2009
    Cupertino, CA
    1,966
    Umm... POP?
    Pool Owner Patience.
    --paulr
    BBB "Intermediate Swimmer"
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    oops...missed that...sorry
    11,969
    You did say "need". You don't "need" floc, though some people like to use it. It's costly, it does work in some situations, but a need? No.
    POP. Definitely POP!
    Mar 2009
    Midwest
    101
    Well in my book, I "need" the floc if it will save me more than 40-60 minutes of work or so. Considering my swampy situation.
    Ah, I guessed patience, but couldn't figure out the rest.
    Guest
    don't know how well floc will work with a robot cleaner. It is usually better used with a manual vacuum and a filter that can vacuum to waste. Robots will probably disturb the settled stuff too much and cause it to mix back into the water.
    I would hold off on the floc.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Pardon my ignorance,but, what the heck is floc
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
  20. Back To Top    #20
    Mar 2009
    Midwest
    101
    Some solution you pour into the pool and it makes the little particles get grouped together (congeal) a bit so that you can actually scoop it out.
