Thread: Opinions Please: Salt System with Jandy Aqualink RS
    Jan 2012
    Las Vegas, NV
    9
    Hello all, I have a Jandy Aqualink RS One Touch controlling my pump, heater, valves, lights, etc.
    I'm looking to purchase a salt water system.
    I've read that the Jandy Aquapure will talk with my Aqualink and provide system info through the one touch display in the house.
    My concern is from the reviews I've read of the Jandy Aquapure. It *seems* to have more issues than the Hayward or Pentair systems. Although a lot of the reviews I've read are from several years ago.
    SO - Would you all steer clear of the Jandy Aquapure? Has Jandy addressed the issues with the Aquapure salt system?
    Am I better to give up a little in house functionality through the one touch and go with a (seemingly) higher quality Pentair Intellechlore unit?
    Thanks for any advice,
    Brian
    [center:32ql66cj]15,000 gallon, cartridge filter, IG, pebble pool owner
    (Built-in, spillover spa not in use right now, leaking)[/center:32ql66cj]
    May 2016
    Casa Grande,Az
    6
    Re: Opinions Please: Salt System with Jandy Aqualink RS
    I don,t know what specific issues you refer to but I have the Jandy Aquapure system. If you are refering to the Flow/Temp/Salinity sensor failure I have just installed a new design one (Tri-sensor Replacement kit) which has the a sensor interface module in line but hanging outside the Power Center. One touch works well for me. Hopefully someone who has knowledge of 2 or more of the systems will fill you in.
    Joe D
    10000 gallon plaster, with adj Spa, Jandy Purelink system with Jandy SWG, Jandy CL series canister filter system, Jandy 2 HP PHPF series main pump and a PHPF water feature 1 HP pump, non working Paramont O3 system. Pool built in 2007
