Thread: Menards bleach adding cya??
    Jun 2015
    edgar
    5
    My pool had a cya measurement of 20 a week or so ago. I have only been adding menards 12.5% bleach as needed and had (1) 3" chlorine tablet in a floater. Today my cya measures 45. I checked it 3 times just to be sure. What could be going on?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Menards bleach adding cya??
    Welcome to TFP
    What as the temp of the water when you did the first test, if it was below 70 it could have been off, and that 1 puck added CYA and I bet there was some leftover in the floater...
    Still, 40 CYA is just about perfect...
    No sodium hypochlorite would contain cyanuric acid. Most likely just test error.
    Support the site
    Jun 2015
    edgar
    5
    The water temp was fairly cold. I will check again at a warmer temp.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The CYA test is known to be off with cold water samples, but works well when sample is at swim temperature, so if testing a cold pool allow the water sample to warm up.
