Thread: First time opening a pool, need help
    May 2016
    elizabethtown, pa
    2
    I attempted to open my pool for the first time today, usually have a company open and close it but figured I would do it myself this year. Everything was going fine until i turned the pool filter on. Water had started coming out the return lines in the pool and then I noticed water was coming out of the heater rather steadily(from the inside). I'm attaching a picture of my filter/heater, anyone have any ideas? Also this piece was with all the plugs and baskets and I cant find where it goes, could it be why its leaking?
    May 2014
    Central MA
    3
    Re: First time opening a pool, need help
    I have no idea what the white plastic thing is.
    Take off the lower front cover of the heater. There is a pressure switch that the pool company that closed your pool may have unscrewed. Same thing happened to me last week when I opened.
    26K gal, gunite pool/hot tub, 2 HP Jandy Stealth pump, Hayward S310S sand filter with vari-flo valve, Hayward poolboss automation, EUS Mark 6 heat pump, Hayward H Series propane heater, Pentair 320 chlorinator, Hayward PSA24 valve acuators, Air Supply Silencer blower.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    Please add your state to your location in your profile so it shows up over there <-----, climate is often an important factor when we help you with your pool.
    Aug 2014
    Northern IL
    4,615
    Look on your heater and get the make and model of the heater. Google that info with "parts list". You should get a schematic which shows you if that part belongs anywhere.
    May 2016
    elizabethtown, pa
    2
    the plastic thing I found out is a skimmer to main valve drain, but I still cant figure out where it goes. Hayward Valve, Skimmer To Main Drain Wg (sp1082gv) - INYOPools.com
    When I take off the lower cover to the heater I find a little knob that turns that says on and off but doesnt say what it is. I tried turning it of and on, neither helped
