Results 1 to 8 of 8
Thread: Lowering TA and dropped PH too much. Issues?
    May 2016
    Scottsdale/AZ
    15
    I dropped my PH to about 6.7 after I added too much acid last night. I'm aerating, but it takes forever to increase.
    Readings in case it's needed.
    Ph: 6.7
    Fc: 8.5
    Cc: .5
    Ta: 90-100
    Cya: 60
    Do I have anything to worry about?
    Thanks!
    ~16k Gal, IG white plaster pool - Built 1986 re-plastered 2012, Pentair CC 420 cartridge filter, Pentair variable speed pump both installed 2015, Barracuda cleaner, TF-100 test kit
    Jun 2014
    15,074
    Re: Lowering TA and dropped PH too much. Issues?
    That is quite low. I guess I'd have to know more about how your pool (pH) normally responds to aeration. If it usually rises fast, then I'd just keep aerating. But if it drags-on, you might add just a little borax just to help get it back to about 7.0, then let aeration take over.
    May 2016
    Scottsdale/AZ
    15
    Quote Originally Posted by Texas Splash View Post
    Normally it rises really quick, but Ive noticed since Ive been reducing from a TA of 240, its slowed down. Yesterday my ph was 7.4 (TA 140) and after the kids swam for several hours it jumped to 7.6. I seem to get a .2-.4 ppm increase per day while aerating.
    If I let it be for a couple days am I at risk of any sort of irreparable damage?
    Jun 2014
    15,074
    Not for just a couple days. You have no heater or copper lines, so we're just concerned for your plaster (CSI level). But if it doesn't start to rise soon, you can give it a little "encouragement".
    30,415
    I'm almost on the same page as y'all but I would rather bring it back to 7.2 if it's not there in 24 hours. A couple of days would make be uncomfortable.
    20 Mule Team Borax will put you spot on where you want in 15 minutes.
    May 2016
    Scottsdale/AZ
    15
    The ph has gone up to 6.9-7.0 after I aerated all day yesterday. I've turned the aeration back on. From the sounds of everyone is that I'll be ok if I get it up to 7.2 today. Correct?
    Thanks for everyone's feedback.
    Jun 2014
    15,074
    Yes, that's much better.
    30,415
    Yeah, good work. Lower than 6.8 gets into an "uh-oh" and the last thing anyone needs is for the expert pool guy to say, "uh-oh"!
