Results 1 to 16 of 16
Thread: Just opened pool and did 1st test w newly bought tf-100
    May 2016
    Pompton plains/nj
    10
    I did the cy test and the black dot remained clearly visible. so I guess this means my cy is 0???
    fc o
    ch 50
    ta 110
    salt 1100
    what do I adjust first?? And do I adjust all before shocking?? Pool is pretty clear with some algae.
    9,000 Gal, 12' x 28' x 4' deep, White Fiberglass In Ground, Hayward cartridge filter & SWG, Variable speed pump, No heater.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Just opened pool and did 1st test w newly bought tf-100
    You don't list what your pH is. You need to adjust that to 7.2 and follow the SLAM directions.
    SLAM
    Support the site
    May 2016
    Pompton plains/nj
    10
    Ph 7.0, it looks just under 7.2
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome to TFP
    you're a little low on PH but fine to start your SLAM.. once done with your SLAM then we will get everything else going
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP!
    Yes, your CYA is 0. Add 30 ppm in a sock, here's how, Pool School - Recommended Pool Chemicals. Adjust PH to 7.2 and SLAM away. The other stuff can wait until it is finished.
    May 2016
    Pompton plains/nj
    10
    Ok I finished Slamming, and the pool is clear and did not lose any FC over night.
    FC - 4, CC - 0, PH 7.3, CH - 50, TA 100, Cya 0 (I have cya dissolving in a sock in skimmer)
    I have a staining problem also, (put vitamin C tabs on areas and it removed stains), so I also want to give pool a dose of absorbic acid, then Metal sequestering agent.
    What do you recommend I do 1st ???
    May 2016
    Pompton plains/nj
    10
    I forgot Salt 1000
    30,419
    Wow! You're doing a bunch of catch-up.
    I hope you will slow down a bit and make sure your pool has been sanitized. That said, if you have the AA and are ready to go for it, there is an article in Pool School you should read first.
    May 2016
    Pompton plains/nj
    10
    Thanks, I have been shocking, vacuuming, and cleaning filter since Saturday, so it is now sanitized. So you think it is better to treat the stains now and then adjust everything after that??
    30,419
    No. I would like to see your numbers stay stabilized for a day or two. But, if you say you have it down pat and you have no balance issues and understand how to manage your pool, then it's time to remove the stains.
    Most folks can't go that fast but we'll certainly help you if you decide to start stain removal.
    May 2016
    Pompton plains/nj
    10
    Ok Thanks Again. I am going to wait another day. Then I will follow the stain removal instructions. After that I will wait another day, then try to get all else correct, such as raise CH, raise salt, raising cya (in progress).
    The pool was installed 3 yrs ago, and I filled it with city/town water, but this town gets most of its water from Township wells, so thats where the metals must be coming from. I think next year I will replace the water with purchased water.
    May 2016
    Pompton plains/nj
    10
    Dave,
    I did take your advice and waited before doing the stain removal (ascorbic acid treatment). I just did it last nite.
    At 6pm fc was below 1. I put in 1 lb of acid, very slight change after 45 minutes. I put in 1 more Lb of acid, still only very slight change, after one more hour. I put in 1 more lb of acid, and still very slight change. I decided not to add the Metal Sequester until morning. In morning pool still had visible stains, just a slight improvement from last nite. I then added the Metal Sequester at 8am. I checked the pool at Noon and all the stains were gone. It seems like the stains did not clear up until I added the Metal Sequestering Agent. Is that Possible??
    Anyway the pool looks like new again. Thank You.
    I will now get the ph and FC back up slowly.
    30,419
    Absolutely. The sequestrant moves the precipitated material back into a soluble form and they disappear. Be aware that the iron is still in there and you will need to add sequestrant from time to time to keep it from reappearing.
    Jul 2014
    Hope Mills, NC
    567
    Shouldn't your salt be up around 3000?
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    May 2016
    Pompton plains/nj
    10
    1000 was my salt reading from May 25th, when I opened the pool. The salt is now good.
    May 2016
    Pompton plains/nj
    10
    Dave,
    I adjusted the ph yesterday (it went down to 6.8 from the acid) and got it up to 7.2 right away with Borax. Now I have been adding about 32 fl oz of 8.25% bleach and then rechecking. I have done this 4 times (added a total of 1 gallon bleach), but still zero FC. I guess this is normal also?? This morning I also put my SWG up to 100%. My plan is to keep dosing with 30 OZ of bleach and keep re-checking. Is this what I should keep doing??
    By the way all the tests were as follows 24 hrs after the Abscorbic acid treatment.
    FC 0, PH 6.8, TA 80, Cya 40 I still need to get this up, CH 220
