Results 1 to 9 of 9
Thread: What are all these pipes?
    Nginerd's Avatar
    May 2016
    Howell, MI
    46
    I was browsing the photo gallery of a local pool builder and I saw quite a few pictures taken in the middle of builds that had a lot of pipes sticking straight out of the ground that weren't there in the finished pictures. Who knows what these are (pictures attached...I think )?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,181
    Re: What are all these pipes?
    I'm not sure about the second photo with the white pipes, but the top one with the green pipes look like they are set up as dry wells. This gives them a place to drop a small pump to remove ground water when the pool has to be drained. But, that is just a guess.....
    Support the site
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    +1, I agree, the big problem with vinyl pools is water under the liner, this lets them pump the water out from behind the liner..
    Nginerd's Avatar
    May 2016
    Howell, MI
    46
    Are you suggesting this is only temporary to remove water during the build? Because the pipes are completely covered with concrete in the finished product with no obvious accessibility (finished picture attached). Even if that's what the green pipes are, what the heck are the white ones for, they are everywhere?!
    Coming Spring 2017
    IG Vinyl, 18 x 36 25k gal, spill over spa...rest is TBD
    Feb 2016
    Atlanta, GA
    145
    Would these pipes provide some sort of support for the decking?
    May 2016
    Navasota, Tx
    76
    They look like French drain piping. There is probably grates on the finished deck or they slices holes for deck draining and wanted them to blend in.
    Brett
    Nginerd's Avatar
    May 2016
    Howell, MI
    46
    Picture of finished product (sorry, should have included this in the last post), I know the resolution isn't great so hard to see for sure, but I don't see any drains in the full res image.
    Coming Spring 2017
    They are piers that get filled with concrete during the deck pour for slab support should any settling occur.
    Nginerd's Avatar
    May 2016
    Howell, MI
    46
    AH, YES...I think you got it alex, that makes sense! allinspector you were on the right track too, Thank you!
    Coming Spring 2017
