Thread: Mr Spa hot tub from 1988
    Nov 2015
    Santa rosa ca
    15
    Just picked up one of these. It was free. It looks like it's in excellent condition too. Filled it with water and ran it. Only a couple of issues.
    1. Small leak at top water outlet. Leaks from underneath, but you can see where it's leaking. Wonder if the chrome piece screws off from the housing?
    2. Not sure if the heater works or really how to work it. Light doesn't go on. But I don't have a manual for this thing. Anyone know how to run it?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Mr Spa hot tub from 1988
    I found this
    1983 Mr. Spa Operating Instructions
    Balboa makes a nice little kit to replace everything except the pump..
    Balboa Spa Controls. Balboa Control Systems Packs.
    Nov 2015
    Santa rosa ca
    15
    Quote Originally Posted by cowboycasey View Post
    I found this
    Wow, thanks for that information. Very valuable.
    Are you saying one of those kits will replace the control module in the Mr. Spa?
    Jul 2013
    Fletcher, OK
    3,353
    exactly, you change everything over to new modern tech, new heater..
    If you are thinking about that I would replace the pump and filter also, that would update all the old equipment
    Hot Tub Pumps | Jet, Circulation and Swim Spa Pumps
    this is a good filter but I replaced mine and went to a 100sq ft same type
    Waterway 502-5010 Filter Assembly
    I am just using this company for links, I am not sure if they are the best priced
    Nov 2015
    Santa rosa ca
    15
    Would I need to replumb all of this then? None of this just bolts in?
